I have an Antec Sonata Quiet PC case with a 380 watt power supply. Inside is a AMD Athlon 2600 XP+ CPU on an ASUS A7V880 motherboard, 1 GB RAM. It has two 80GB Western Digital hard drives and a Lite-on 16X DVD-RW drive that works fine. I'm not sure what the video card is, but I replaced it a few years ago. The procesor is old and slow. I'd like to keep my Antec PC case and get a new motherboard, memory and power supply. My current configuation has an Echo Mia audio chard. I use the computer for audio purposes (live recording, editing, mixing). My current system is optimized for audio. Do you think I should try to keep the Antec case and get a new motherboard, etc, or start over with a new PC? Will it be very complicated to replace the motherboard and power supply? Will I be able to use the old sound card? It's sixyears old, but it is still being manufactured. (http://www.echoaudio.com/Products/PCI/MiaMIDI/index.php) Here are specs for a computer from a reputable company, optimized for recording purposes. I'm looking for something with similar specs: Motherboard: Intel w/H55 chipset CPU: Pentium Dual Core 2.80GHz Hard Drive: Seagate 500GB SATA RAM: 2GB DDR3/1333 Optical Drive: DVD+/-RW with LightScribe Video Card:Intel Integrated HD Graphics, 1 VGA1, 1 DVI, 1 HDMI Ports: 8 x USB 2.0, 1 x LAN PCI Slots: 1x PCIe 2.0-x16, 2x PCIe-x1, 3 x PCI Card Reader: Multimedia card reader
  • andylaster Jul 28, 2010
    The processor is old and slow. I'd like to keep my Antec PC case and get a new motherboard, memory and power supply. My current configuration has an Echo Mia audio chard. I use the computer for audio purposes (live recording, editing, mixing). My current system is optimized for audio.
    Will I be able to use the old sound card? It's sixyears old, but it is still being manufactured. http://www.echoaudio.com/Products/PCI/Mi...
    I'm thinking of swapping out the motherboard, add new memory and hard drives and a new power supply. Is this something I should not undertake unless I'm an expert?
    I'm looking to end up with a computer with specs like these: Intel w/H55 chipset CPU: Pentium Dual Core 2.80GHz Hard Drive: Seagate 500GB SATA RAM: 2GB DDR3/1333 Optical Drive: DVD+/-RW with LightScribe Video Card:Intel Integrated HD Graphics, 1 VGA1, 1 DVI, 1 HDMI Ports: 8 x USB 2.0, 1 x LAN PCI Slots: 1x PCIe 2.0-x16, 2x PCIe-x1, 3 x PCI Card Reader: Multimedia card reader
    Basically, I need someone to walk me through the entire process. I also need someone who is an expert with dealing with audio on a PC, and someone who can tell me what type of motherboard, memory, power supply I should buy. Which ASUS motherboard will fit in this Antec sonata case?
  • 560 Answers
Hi. Antec Sonata case is nice and you can still use that with a new mainboard and power supply. When you buy mainboards, it comes with a back panel to make sure that the ports are secured. The new mainboard has PCI slot that you can use for your Echo Mia audio card.
When replacing mainboard, make sure that all screw holes on the mainboard has its matching standoffs on the casing. Remove old standoffs that doesn't match the holes on mainboard and put new ones if necessary.
For experienced or hobbyist person, building his/her own computer is worth spending time. So if you think that building your own computer is worth your time then go ahead and do it yourself.
Let me know if you have questions. Thanks.
Note: Just remember, buying a new set of PC will save you time and energy but you can gain knowledge building your own PC :) Good luck.
Posted on Jul 28, 2010
    President:
  • 567 Answers
Hi you can use the same case if you like, but once you change the motherboard you have to change the memory and the CPU, you can keep the old hard drive if want or replace ti with one that is bigger in capacity and you.Those specs are good it will give you a very excellent computer, you should go for it.
  • 2 more comments
    Okay, do you know what motherboard I should buy? Should I get another ASUS? Which ASUS will fit in this case? Should I purchase it with RAM. Basically, I need someone to walk me through the entire process. I also need someone who is an expert with dealing with audio on a PC. Can you help me, or should I repost my question? thanks!
  • Hilton Bristol Jul 28, 2010
    Hi you can buy an ASUS motherboard yes, but they are expensive but work fine, but there are other popular brands out there which are cheaper such as DIOSTAR, GIGABYTE,MSI and many others but you will get the best results from ASUS.There are two types of CPU,:INTEL and AMD and the CPU must match the motherboard, for example if you buy a 775 socket motherboard you must buy a 775 socket CPU, so when you go buy its good to buy all parts from one store.
    You ask the question i was putting together the answer for you
    okay then i have no need to give you more details.
2 beeps, no post on my Asrock Extreme3 970
two things:
your RAM's its not fitted right or in right spot.
too small power supply, its to narrow in watts, should have 750 Watts at least.
Mar 22, 2012 | Computers & Internet
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
I have this old laptop and its called a compaq (presario 2500) well yesterday i brought the sims3 game for it because the laptop dosent have internet. When i installed the game it says windows xp has to...
Thanks for using fixya.
My name is Carlo.
Your computer might not pass the system requirements that's why it has an error. Or, you can try installing it one more time and check if it will work. Computers do mess up sometimes.
Here's the system requirement of SIMS 3:
Desktop PC (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1 GB of RAM
GPU: 128mb Video Card (GeForce FX 5900 or Radeon 9500)
Desktop PC (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 1.5 GB of RAM
Laptop (Windows XP + SP2):
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
RAM: 2 GB of RAM
Read more: http://pc.ign.com/articles/939/939410p1.html#ixzz10TQHijZi
IF your computer does not pass the system requirement, then you cannot play sims3 in your computer.
I hope this helps. Thank you for using fixya
Please leave your comment and ratings. Thanks
CARLO
Sep 24, 2010 | Computers & Internet
My Asus A7V8X-X AMD Athlon 2500 motherboard was custom built. There are three fans, front,CPU, rear. There are only two motherboard connections, 1 chassis, 1 CPU. rear is disconnected. How can I connect...
If your rear fan has a small 3 pin connector and there are no connections of that type on your motherboard, you will need an adapter to connect it to a four pin molex connector from your power supply. Something like this...
http://order.store.yahoo.net/cgi-bin/wg-order?yhst-39083765508394+4to3
Aug 05, 2010 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
I bought this motherboard: ASUS M2N68-AM SE2 Motherboard CPU Bundle - AMD Athlon X2 7550 2.50GHz OEM Processor, Geforce7025/nForce 630a, mATX Motherboard back on June 30, 2009 from www.tigerdirect.com....
I guess this is happening because of the CPU getting heated, Kindly check if the CPU heatsink and the fan is seated properly. Also check if there is any power issue, try to connect the system to another wall socket
Oct 01, 2009 | ASUS M2N68-AM SE2 Motherboard
I would like advice on upgrading my Graphics card
Unfortunatly your still running low end CPU power and low end agp graphics. Your going to pay 150-200 just for a fair PCIe/AGP HD/3D VC. If $200 doesnt hurt (and this is the lowest price best option), then might I suggest Mobo/CPU/RAM for around $200 that would do the trick and allow for future upgrades. You might also need a power supply. I just built one less than 3 weeks ago for a friend and it fairs against my own gaming comp.
MY PC...
AMD ATHLON 64 X2 DCP 6000+ 3.01GHz
NFORCE6M-A V:2.0
8GB PATRIOT
XFX 8800GT AD 512MB
500W PS
NEW PC....
Gigabyte GA-MA785GMT-UD2 MB $90+/-
AMD Athlon™ II X2 250 BOX 3.0GHz (CAME W/FAN)$70+/-
AND 4GB OF DDR3 1066 RAM COMPATIBLE WITH MOBO $40+/-
THE ONBOARD VIDEO IS CAPABLE OF USING 700MB
OF RAM...RGB/DVI OUT.
HOPE THIS HELPS.
Sep 12, 2009 | Asrock K7VT2 Motherboard
Found no display my PC. ( Mother Board ASUS M2N68AM , Ram 1 GB 667 DDR2,CPU AMD Athlon 5000 )
Do u mean there no display adapter on your motherboard? If that's the case some ASUS motherboards don't have on board video or graphic cards. You can buy an addon cards available in most computer shops, You stand a chance of getting a much better graphics card than those that come with the motherboards.
Aug 24, 2009 | Computers & Internet
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
Asus Premium Vista M2n32-Sli
Dear Riddler2002,
First thing u have to check the SMPS if it is not working properly then it will restart automatically not working properly it means that the SMPS not giving the excact power supply to mother board now the question is how can u check the SMPS working fine or not do one thing borrow a SMPS through u r friend connect that SMPS to u system if it working with u r friends SMPS then u have to change u r SMPS if still u r getting same problem then u have to check u r system RAM if RAM not work Properly then it will get this type of problem so Change the RAM and connect another RAM to u r system if the RAM is working fine then it will work properly.
Regards,
Bittu_8
Feb 13, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Upgrade P5RD1-VM motherboard to the gaming PC
Your pc is not for gaming right now because you are using Intel Pentuim 4 Mother board and CPU. Amd Athlon is best for gaming. I have a AMD Athlon 4200+ X2 with 4gb Ram and Nvidia 6800 256mb OC. to upgrade your computer to a gaming pc. you will need to switch your motherboard and cpu for best performance on games. in order to do that, you might need a different case for your new motherboard. because the one you have might not be right for the AMD Athlon motherboard unless you have a custom made computer. other than that everything is set for you. if you have less than 1gb ram you might want to add more. because the games they are coming with right now is 1gb minimum or required.
i hope that answers your question.
Thank You
Dec 08, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
Alun Cox
David Payne
David Payne
