Question about Andis T-Outliner Hair Trimmer
I have bought new blade and still want cuy right
  • 2,926 Answers
Can you provide more details on this problem. I understand you replaced the blade, but What is the shaver doing now?
Posted on Jul 28, 2010
Bought the new ryobi 7 1/4 inch miter saw. Factory installed blade stops but spindle doesn't. There is an inner ******/washer, then the blade, then an outer ****** and then the bolt. Why is blade stil
The shoulders on the washers have to be properly aligned with the hole in the saw blade so the nut can tighten properly. Are the washers turned the right way? Try flipping one or both the opposite direction.
Sep 13, 2014 | Saws
Need replacement glass for Starbucks blender... Anyone know where to find?
I bought an Oster 6 cup glass and it works perfectly on the Starbucks Barista blender. It has to be the 6 cup NOT the 5 cup or the blade mechanism won't fit. the 6 cup screws right on your old blade base and it was $10 new on Ebay including free shipping.
Aug 14, 2014 | Blenders
Why2004silverado cuy off after idelingfor15minutes?
have the OBD codes read as this will pinpoint the sensor/switch that is faulty
May 08, 2014 | 2004 Chevrolet Silverado 1500 Crew Cab
Wiper blade stands up in the middle. Push it down but it pops back up when you turn it on?
check and adjust the blade length. Ensure that in installing the new blades that you used the right sort as if the grooves in the blade or too tight on the arm clips this problem will result. The blade has to move freely in the arm clips
Dec 15, 2013 | Cars & Trucks
I bought a second hand Power Devil Mitre Saw PDW 5013. It has no instruction manual and I need one.On starting up the saw, the blade spun but sounded terrible, loud and not right. On trying again, several...
Try the blade first. It should be tight and have no real wobble to it. Although my first guess would be the brushes, These are generally accessible from the outside. There is often a number or something to identify the brush so that you can get a proper replacement pair. If the motor starts right away and the blade does not then the blade is loose. re- reading your post it could well be the blade. Often these are reverse threaded, so you tun them clockwise to get it off. You may well want a new blade anyway, and there are different types for different jobs. Watch your fingers and unplug the saw when messing with the blade- it is easy to hit the switch when undoing the blade.
Jun 10, 2011 | Saws
Husqvana LTH 2038 model, blade is bent so bought new ones, when i tried to put on the new ones the right hand side one hits the deck. What could it be (checked the blades they are the right ones)
Probably bent jack shaft or bearing. Or the deck bent, where the bearing is mounted. It is possible but probably just jackshaft. Or when you put the blade on it got hung on the part that go's in the center of blade and made the blade sit crooked. Thats what I do.
Jan 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Can get it right
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Jun 11, 2009 | Oster Golden A5 2-Speed Universal Motor...
Andis T-Outliner Hair Trimmer Logo
26 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
