Question about Keurig B60 Coffee Maker
Keurig says brewing...but nothing is happening
Top of the line Keurig machine (platinum model). Reset the entire system. Times, etc.... Says ready to brew, ...Hit "Brew" light says "brewing" but nothing is happening
SOURCE: Keurig B50 Ultra brewer
This is a known problem with the B50 which Keurig will acknowledge if you press them hard. Some users have suggested trying to clean the check valve just inside the water outlet but the best solution is probably to call customer support, complain like crazy, and take the discount on a new machine that they will offer you. Apparently, this problem occurs much more often with the B50 than with more recent models, which may explain why it isn't on the market anymore.
Posted on Jan 23, 2008
  • 28 Answers
SOURCE: keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Posted on Feb 07, 2010
  • 7 Answers
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Posted on Mar 29, 2010
  • 5 Answers
SOURCE: Keurig Platinum shuts off after one brew. Will
I came up with a very simple workaround to fix this issue:
http://www.nate-lewis.com/blog/?p=288
The problem is with the water tank not having a proper seal to the brewing unit.
Posted on Jun 05, 2010
SOURCE: My Platinum Keurig says it is ready to brew but
My B70 has worked good for about 6 months. Lately it won't brew a full cup of coffee or water for that matter. I have run Limeaway, and also vinegar throught it but nothing works. It seems to me the pump is too weak to make coffee before an apparent time-out occurs.
Posted on Dec 15, 2010
How do I fix a Keurig V1255 with a flashing LCD display?
Keurig Platinum Reset for the Not Ready Light - YouTube
? 1:21
https://www.youtube.com/watch?v=xjWIQpttTc8
Jun 22, 2010 - Uploaded by Lsailor1
This is a reset method for using on the Keurig Platinum B77 coffee ... Show more ... set to brew in morning ...Missing: v1255
Fix Keurig Vue V700 Not Brew
Nov 14, 2015 | Vue V1255 Professional Brewing System...
Why did our keurig b70 just quit working?
Try unplugging it for 30 sec. and plug back in. Give it time to reset. Hope this helps
Feb 05, 2018 | Keurig Platinum B70 Coffee Maker
Frequently it says it brewing but nothing happens...this happens about 40% of the time. This machine is only 9 months old ...could the thermostat be bad already?
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 24, 2011 | Keurig Platinum B70 Coffee Maker
It's says it's brewing and the water will go into the "warming chamber", but then it like freezes and the Keurig won't do anything. It just continues to say brewing, but nothing...
heatman101 ./.,.,
Aug 13, 2011 | Keurig Platinum B70 Coffee Maker
Machine says "brewing", but nothing
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 01, 2011 | Keurig Platinum B70 Coffee Maker
Keurig B60 Coffee Maker Logo
248 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
