Question about Speed Queen AWS45NW Top Load Washer
How do I remove the agitator on my Speed Queen AA4211WE? There's no cap! It all appears to be one piece.
I just did that. Just pull up really hard. Now.. how to get that other thing off to pull the tub, I can't figure out, all bolts are removed.
Posted on Sep 13, 2010
    Problem Solver:
  • 5 Answers
Mine is a Kleenmaid LWK74AWMFG in 2002 Made by Speed Queen. I could not lift it off using the above tips until I filled the bowl by setting on "Hot Water Wash" this expanded the plastic and after draining the bowl some to grip the agitator lifted of easily reveling the Hex screw head. Bingo
Posted on Feb 25, 2013
How can i get the agitator off a speed queen modle number AWN412SP111TW01
If its a standard top loader there should be a cap you can pry off on top of agitator. Screw or bolt is under cap.
Nov 27, 2017 | Speed Queen Washing Machines
How do I remove the agitator on a speed queen washer model # aws17nw
It has a large nut under the cap on the top of the agitator, but it will be the devil to remove due to a tight fit and corrosion.
Sep 28, 2016 | Speed Queen Washing Machines
HOW DO I PULL AGITATOR ON A SPEED QUEEN WASHING MACHINE MODEL AWS76NW
down the center about 6 inches deep u have a 7/16 inch screw remove it then u can pull the first part of agitator, the second pc can be pulled out after but may not be that easy may have to pry it up
Mar 01, 2015 | Speed Queen AWS76NW Top Load Washer
Sped Queen motor overload
It's 20 years old and you want to repair it?
Mar 19, 2014 | Speed Queen Washing Machines
Smell coming from AWN32 speed queen top loading washer
All washing machine "smell" when the lid is left closed for more than one day. If it is really bad it might be something inside the body of the machine or something caught under the agitator.
Inside the body work. Unscrew the three screws at the bottom of the front panel. Lift the bottom of the panel forward and up. Remove. Make sure the machine is unplugged and switched off before reaching into the body work. Look for something "smelly"
Agitator - switch off and unplug - depending on the model unscrew the top cap on the agitator. Some models do not have an screw cap although it might look so. Reach with both hands into the machine and grab the agitator at it bottom flanges hands opposite each other. Pull up hard - it does not let go easily- make sure it doesn't have a top screw cap. To replace just push back until it clicks or replace and tighten the top cap.
Dec 13, 2013 | Speed Queen Washer Top Load AWN432
How do i take agitator out of speed queen awn412 washer
To remove the agitator all that ya need to do is grab the bottom edges of it and pull it straight up and out..if locked onto a hub under it and is just held to that hub by several tabs
Gene
Aug 25, 2011 | Speed Queen AWN412 Top Load Washer
Just bought a speed queen top loader model LWS 17
that top cap/container on top of the agitator is for fabric softner if you use it. As to why it wont spin possible overload or if you bought a second hand machine could be a belt or gearbox ??
Suggest you put the detergent in the bowl, the fabric softner on top of the agitator, drop the clothes in till it's full not pushing down on the clothing - the weight rating of the washer is for wet clothes weight not dry clothes. If this doesn't get you going in the right direction then call someone who knows what their doing, it's too good a machine to risk stuffing it if you dont know what your doing
Dec 10, 2009 | Washing Machines
#awm693w,removing agitator to replace seals
Unscew the cap on the top of the agitator, then hit it back and forth with your hand and it will break loose. I just did it to mine today and it has not been of for twenty years.
Feb 02, 2009 | Speed Queen AWS75NW Top Load Washer
Spots on white clothes
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Speed Queen AWS45NW Top Load Washer Logo
1,338 people viewed this question
Top Speed Washing Machines Experts
Charles T Nevin
Charles T Nevin
 steve
steve
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
