Question about Music
We have a boss recorder studio that quit turning on. And we have a manufacter warrenty.what can we do? Get it replaced or fixed where?
  • 268 Answers
Ofcourse, when u have valid warranty , do not attempt to do anything else. Take it back.
Posted on Jul 27, 2010
It just wont turn on, and i'v tried other power supplies that deffinately work and it still wont. help!
Use the correct PSC power adapter. 9 volts, 1 amp... not sure of the polarity... searched all over for the spec. The unit draws 900ma so you need a 1 amp supply. Most "universal" supplies will not provide enough current. If you have tried the wrong polarity you may have damaged the unit.
Sep 14, 2011 | Roland Boss BR900CD Digital Recording...
Hi. My boss br 1600 will n ot start. I turn on the power source and it will blink for a split second and then nothing. I checked for loose connections but everything seems ok. Any suggestions?
I have this problem with mine. I've did some research and with the boss br 600 this problem can arise quite often .it's caused by a faulty power diode apparently except in that case I've never heard ofrom the screen blinking at all (which my 1600 also does) I wonder I'd this problem can be the same for a br 600 as the br 600
Sep 08, 2011 | Boss BR 1600 Cd Br1600 Cd 16 Track Digital...
Does anybody know how to fix built-in microphones on rolland BR-600. When I attempt to record, the only sound that gets recorded is noice (hissing sound), and that only after cranking rec volume and mic...
Most of these have a SETTING in the menus that selects the source from different mics and/or line inputs. If the setting is to the line input instead of mic, and no audio is connected to the line input it will act like you described.
Jun 23, 2011 | Boss BR-600 Digital Recording Studio
My Boss BR-1180 was working fine but said NO CD DRIVE so I replaced the cd drive and as soon as I did I turned it on it reads BOSS BR11-80 and the HD ACCESS light stays lit but nothing else happens. Did I...
hdd should not be damaged, if your hd and cd are on same ide cable it might be taking the cd as master and not the hd, ensure the jumper on the back of the new cd drive is set in the same position as the old one was, as test remove cd and boot system, hd should act again as usual. this will show that there is a ide conflict.
my assumption is that your cd jumper should be set to slave or cable select position.
you may have to try each until you find the position that works.
I hope this was useful.
regards Martin.
Mar 24, 2011 | Boss BR-600 Digital Recording Studio
How do i connect active speakers to a BOSS br 1600 digital recording studio? The speakers are M1 Active 520's. The manual does not seem to cover it, my naivete in many aspects of recording, I'm sure, is...
I would come out of the line out jacks on the studio into the line in jacks on the speakers. Make sure both ends of the cables have the correct plugs on them. I'll include a link in case you don't have the correct manual:http://www.alesis.com/content1023
Mar 22, 2010 | Music
BR8 Digital recording studio lights up, but it doesn't do anything else
I called Roland at the number that you provided and gave they following proceedure which will re-intialize the BR 1180 and ERASE everything that was created on the HD:
  1. Simultaneously hold down button beneath volume control at track 5 and Undo/Redo button at upper right
  2. Press power button while holding down buttons as above, until test menu comes up
  3. Turn selector dial untill initialize screen shows
  4. Prdess ENTER and initialization will start
  5. Once initialization is completed, power off unit and then power it back-up.
NOTE: This proceedure erases all data!
Apr 16, 2009 | Boss Micro BR Digital Recorder
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Music Logo
32 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
