Question about Dell HK395 Computer Speakers
I need a new HK395 Woofer Volume PCB (circuit board) for a harman/kardon
  • Anonymous Nov 25, 2013
    I just got this speaker system with other problems, but it has the pcb board you need. email me at rawise at cfl dot rr dot com
  • Brent Potter
    Brent Potter Nov 30, 2017
    I also need this same board got my HK 395 speakers.
    Problem Solver:
  • 5 Answers
Try http://www.redplanettrading.com/search.php?mode=search&page=1. They have the HK395 model for a pretty good deal and they might be willing to cut you a deal for just the part.
Posted on Aug 17, 2010
    I have an HK395 set for parts that has what you need contact me at rawise@cfl.rr.com
I have parts bobbymeadows76@gmial.com
Posted on Nov 05, 2012
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
Crackling static noice
Hi Roovejet.
The capacitor 104 is 0.1uf ceramic has no reading with analogue multimeter in any range of ohms scale.
if it read any of ohms value ,it is bad.
please check the large electrolytic capacitors too and loose connection for the board and.if you have volume controllers clean it with alcohol or contact cleaners.
if your device is older than 5 years it is time to change all the electrolytic capacitors.its sound like foolish but it brings new life and same quality when your buying time to the sound system.
regards.
nuwan
Jan 20, 2014 | Dell HK395 Computer Speakers
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
Question on allowable use
Hi sheawm. You can use your speakers as long they have the mini-plug connector such as ipods, blackberrys, laptops, desktops, etc. so it won´t matter. I hope this helps.
May 08, 2010 | Harman Kardon Harmon Kardon SoundStick II...
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
Popping harman kardon subwoofer
Mine did the same thing all of a sudden. The problem is a AC mains detection circuit that seems to affect many previous HK sub models. The solution that worked for me was to replace capacitor C112 on the main pcb of the subwoofer amplifier. You need to remove it from the circuit board with a soldering gun and replace it with a higher rated capacitor. I used a 2u2 40v and the subwoofer is working perfectly again! :)
Dec 23, 2009 | Harman Kardon HKTS 12 System
HK395 Speakers/Subwoofer Cable
Jul 26, 2007 | Dell HK395 Computer Speakers
Dell HK395 Computer Speakers Logo
1,442 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
