Question about Northstar Generator 13 Hp, 8000 Watt, Trifuel
I have a northstar 13hp 8000ppg generator. I was using it last wk and it was working fine. when it quit. I have checked the curcuit breakers and they are all ok. I have tested the generator and there is no current any where. When I was using it I was just running a couple of small appliances. So I do not beleive it got over loaded. Doug Clark clarksdairy@hotmail.com
  • 3,740 Answers
Hi Doug. Welcome to FixYa I am Kelly. Download this manual and use the applicable section for troubleshooting your Generator.
www.gen-parts.com/Manuals/85680.pdf
What concerns me is you said "there is no current anywhere."
This lead me to believe that given at the time of failure you had a light load on the unit that maybe something simple like a wire has vibrated off a connection somewhere.
Is this a brush type or inverter type generator? If it is a brush type one brush getting hot and moving away from the slip ring assy will cause the exact same symptom.
With the brush block installed you should read a low resistance across the brush block terminals.
If you remove the brush block and one brush is longer than the other one suspect the brush block as the cause.
If it is an inverter type generator there are two types one with an inverter electronics box and the other with one or 2 large capacitors. The one with the large capacitor if the condenser wire has come off or burned, the field will not flash. (Common issue)
There is also a 4 post diode block that must be functioning correctly to have a generator output. There is one terminal 90 deg out from the other three that is the positive terminal. It should read to all other posts in one direction and not at all in the other direction. (meter leads reversed)
This should be enough information for you to isloate the problem. If not just respond here and we can walk through troubleshooting your generator after you have the manual and have done some basic troubleshooting.
Thanks for choosing FixYa.
Kelly
Posted on Jul 30, 2010
Husky 5000 watt generator quit producing power.
You could have a bad circuit breaker button. Replace that and see what happens.
Dec 24, 2015 | Husky Electrical Supplies
Adustments engine speed low rpm
You cannot adjust the voltage output. All generators are rated for 110-125 volt recepticals and usually have at least one 220-240 volt receptical for special appliances that require it such as water heaters, pumps, welders, air conditioners. When one of these higher draw appliances is connected and they begin to draw amperage, the gas engine will automatically increase rpm to produce enough amps. If your generator gauge is showing low voltage such as 60,80 or 90volts for example, then you have overloaded the generator and blown a capacitor, resistor or similar item.
Dec 05, 2013 | Northstar North Star Honda 13hp 8000 Ppg...
Where is the window curcuit breaker for a 2002 honda civic
Its probably the window motor circuit breaker should power all of them and only one doesnt work.
Feb 18, 2013 | 2002 Honda Civic
Our generator keep throwing the curcuit breaker.
Check to see you are not overloading the current rating of the breaker. If not the breaker may be worn out and need replacing
Oct 16, 2012 | Coleman Powermate Premium Plus 6250W...
Generator runs fine- does not produce any power- checked breakers all ok
The voltage regulator for the generator is not work, replace it. Why, if there no dc voltage to excite the stator it won't any output. GB...stewbison
Aug 31, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
McCulloch Generator model FG6000mk 11hp run good until I turn on generator then stop running do you think the generator bad and can it be rebuild ?
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FG6000MK-7096FG6024-966991401.pdf
Jun 12, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
No 240V
check for a circuit breaker that is tripped, as well as a switch that enables 240volt (at the cost of 120 volt current being cut in half.). The switch puts the alternator windings in parallel (120volt full power) or series (240 volt @ half 120volt current).
May 02, 2010 | Northstar Generator 18 Hp, 10,000 Watt,...
Low output from NorthStar 5500PPG
There are a few scenarios that can cause this.
1) The extension cord that you are using is too long / too light of a guage. Try a heavier extension cord, or plug directly into the generator.
2) The alternator has lost its "residual magnetism" and may need to be reflashed. Consult Northstar for instructions and details.
3) The voltage regulator (actually a simple capacitor) may be "weak"
4) The diode for field winding may be bad.
You can get a copy of your manual here, page 40 has diagram and part numbers.
http://www.northerntool.com/downloads/manuals/165911.pdf?cm_ven=natural&cm_cat=netconcepts&cm_pla=Google&cm_ite=http%3A%2F%2Fwww.google.com%2F%26
Apr 02, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
One of 2 circut resets keeps tripping on our Generac generator
If it's tripping a breaker that usually means there is to high of an amp draw on that curcuit.
Are you plugging more things into that particular curciut (or just different but higher amp draw items) than you did last year?
It's also possible that one of the items plugged into that curcuit is wearing out and drawing more amps than before.
If you have an amp meter, plug everything back up just the way it was when you were having problems. Check the main wire going to that curcuit. (right at the breaker)
If your amp draw is greater or nearly the same as the amprating of that particular circuit, then thats your problem.
To many things/to high amp draw on one circuit.
If it is not near the amp rating, and you are getting proper voltage to the breaker, then I would replace that breaker.
Dec 30, 2008 | Electrical Supplies
Northstar Generator 13 Hp, 8000 Watt, Trifuel Logo
494 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Marvin
Marvin
Vernon Taylor
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
