Question about Whirlpool Duet GHW9150P Front Load Washer
F22 code ?? duet locks but will not run - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • 1,382 Answers
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Posted on Jul 28, 2010
Code f22 flashing when i try to start load. the door seems to lock fine
unplug washer and let set 30 min. should reset. plug in, turn on then turn off a couple of times to see if doorlocks and unlocks properly. If not you may need a new switch. That F22 is door lock malfunction. You may need to check hinges and see if they are tight.
Jul 15, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
Jun 28, 2012 | Washing Machines
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting F22 I removed lower front , found door release, opened door I cleaned catch, removed and checked impeller Checked electric connections under the hood Still get F22 code
You likely have a faulty door lock assembly, which is what this fault code is telling you. Most often caused by a faulty switch within the lock assembly itself, you will need to replace the entire assembly. The part is available HERE .
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does F22 error mean?
This fault code denotes 6 failed attempts at locking the door. I have found that this code is typically indicitave of a failed lock. Check the strike on the door to be sure nothing boke on it, and if not get a replacement door lock assy for your machine. You will see the three screws that hold it in and can remove the front spring clamp from your door boot to give yourself access to the door lock.
Good luck to you on this!!
Jun 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet had code of f22. door was locked, i manually got it open but now the controls still do nothing. i tried resesting..
Switch on the machine. Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Feb 23, 2010 | Whirlpool GHW9300 Duet Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
523 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
