Question about Haier HC48C1VAR Central Air Conditioner
It will not blow air out of the vents, the unit turns but does no
This is not the one i have the one i have is a HR36C1VAR. I am wanting to know the warranty on it.
We have nothing but trouble out of our unit HR36C1VAR since we bought our house. Now the heating man is saying we need the wiring diagram so he can replace the wires and rewire our unit from where someone cut the wires now. Does anyone have a copy of this diagram?? ours is missing. I would so appreciate it..Dont have the money to replace unit
Posted on Dec 28, 2010
I have a RUUD gas pack unit.....when you turn on the heat, the blower does not blow any air out of the vents while on "auto". If you put it on "on" it blows cold air out of the vents. What is wrong?
Sounds like the thermostat is hooked up wrong. If the ac doesnt work right its in the thermostat programming or the wiring. Hope this helps good luck
Jan 13, 2013 | Ruud UAMB Air Conditioner
Heater unit doesn't blow any air
If you have no air blowing out it sounds like the blower motor has quit
Dec 28, 2012 | 2005 Jaguar Vanden Plas
My air condition inside unit seems to be freezing up and the air stops blowing through the vents after I turn it off it sounds like ice melting. after a few hours I can turn it back on ,it will blow throuh...
When evaporator is full of ice, check the following;
Note: You may actually need the service of a qualified technician. Proper tools are needed also.
  1. Clogged filter/drier. Clean or replace filter/drier. You have to discharge the refrigerant first then recharge after replacement or cleaning. The system must be evacuated of moisture, dirt,metal chips or any particles that can cause clogging on the capillary tube.
  2. Evaporator fan. The the fan if can be turned manually. If not, realign and lubricate. It should turn freely..Otherwise it must be replaced.
  3. Refrigerant: Check the refrigerant using a gauge manifold. Repair leaks and recharge refrigerant .
Sep 07, 2009 | Goodman CKL60AR60 Air Conditioner
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Unit not blowing exhaust!!!
http://safemanuals.com/brand-user-guide-instructions-owner-manual/MAYTAG, this may help you locate the issue. there may have been some degris that is keeping the blower cage from turning, or the cage may be damaged.
Jul 19, 2009 | Maytag M6P09S2ACOM Air Conditioner
Do vented range hoods blow air into the house?
sound like not installed right,most hoods are convertible and the blower must be rotated to vent outside. Hopes this helps,please rate my solution :)
Jun 25, 2009 | Kitchen Ranges
AC unit outside turns on but no air blows through the vents
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
May 28, 2009 | Heating & Cooling
Your indoor unit pc board is bad, replace it.
May 08, 2009 | Heating & Cooling
There is no air blowing out the vents on the dash board when i turn the ac on
you have a bad control unit, the thing you use to switch from one thing to the other, it needs to be replaced.
Oct 19, 2008 | 1998 Oldsmobile Regency
Haier HC48C1VAR Central Air Conditioner Logo
90 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
