WHEN I SELECT POWER ON,IT COMES ON AS NORMAL FOR ABOUT 5 SECONDS,THEN IT SWITCHES TO A POWER PROTECTION MODE.IS THERE A PROCEEDURE TO RECTIFY THIS ISSUE.
  • 4,234 Answers
There is no specific procedure for this other than to check for shorted output transistors in the final amplification stage. If you can update this with the specific make and model, I may be able to list the most common replacement parts required for that model for this problem.
Dan
Posted on Jul 28, 2010
Error code E000002
That is the error code for a power supply failure or the printer not receiving enough power to heat the fusilier to print. This can be due to an power outage or not enough electricity flowing into the machine.
If the machine is receiving full power, you'll need to get rid this error through entering service mode.
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
NOTE: from this point forward you'll be in service mode which has a 60 operational second window. After 60 seconds it will exit out of this mode and you'll have to start over.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
The printer should restart and be working normally.
Feb 21, 2016 | Office Equipment & Supplies
PROTECT does not come out from the screen
Check the speaker wires for shorts or damage. If none, the amplifier has faulted and will likely require service to restore back to normal working condition.
Apr 11, 2014 | Audio Players & Recorders
What's the difference between a surge and a spike in voltage?
A spike is an increase in voltage for 1-2 nanoseconds.
A surge is the increase lasts 3+ nanoseconds.
Feb 05, 2014 | Electronics - Others
When on the stand by button on display come and display showing protect how do i rectify the protect mode?circuit diagram?
protect mode comes on generally when speaker have shorted. disconnect the speakers & try. If it powers on properly try one speaker at a time till you find out which speaker is causing the problem
Dec 23, 2010 | Denon AVR-2800 Receiver
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Error code 80010006 and ervery time it gets to 38% and it gives me that error code this was when i was tyying to do the 3.30 firmware update
Hello jenky2010
This error code relates to the PS3 having trouble accessing a file. This usually occurs when the PS3 is turned off while saving or accessing a file.
To rectify the problem, you'll have to into Safe Mode, and then select "Restore File System". If you're not sure how to enter Safe Mode, follow these instructions:
1. Turn off the PS3 by holding down the power button until the power light is red, then release.
2. Hold down the power button again. This should be shortly followed by a short beep, indicating that the PS3 is turning on.
3. Continue holding the power button, and after about 5 seconds you should hear a second beep.
4. Continue holding the power button, and after a further 5 seconds, you should hear a quick double beep. Release the power button. If you've successfully activated Safe Mode, you should receive the message" Connect a controller using a USB cable and then press the PS button". Do this.
5. Select "Restore File System". Follow the on-screen instructions.
!WARNING! - SELECTING ANY OF THE OPTIONS IN SAFE MODE CAN RESULT IN DATA CORRUPTION AND/OR LOSS. IF POSSIBLE, BACK-UP ANY IMPORTANT DATA BEFORE PROCEEDING WITH THE ABOVE PROCEDURE.
Hope this helps, good luck. If you require any further assistance, please contact me.
ajblaj
Jul 18, 2010 | Sony PlayStation® 3 (80GB) Console
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
How do I reprogram the 2004 Pontiac Vibe key fob?
To begin programming, follow the procedure.
  1. Set the following conditions: • Ignition off and ignition key out of cylinder. • All doors closed except drivers door. • Drivers door is unlocked.
  2. Insert and remove the key from the ignition switch twice within 5 seconds.
  3. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
  4. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
  5. Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1to5 times to select desired mode. • 1 time for add mode • 2 times for rewrite mode • 3 times for confirmation mode • 5 times for prohibition mode
  6. Remove the ignition key from the key cylinder.
  7. After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode. • In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered. • In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times. • If the prohibition mode or confirmation mode is selected, registration procedure is completed. • If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode. • If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed. • If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
  8. Registering new recognition codes for the add mode or rewrite mode. • Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds. • Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
  9. Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter. • If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters. • If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
Jun 11, 2009 | 2003 Pontiac Vibe
Start up problem.
I suggest you look at the Horizontal output transistor, when it goes short the supply is in protection mode, it is pointless reading voltages at this stage, check the transistor located close to the Horizontal output (Flyback) transformer and normally mounted on a large heatsink. Check the caps in the primary power supply stage....hope that helps..Phil
May 19, 2009 | Televison & Video
 Grubhead
Grubhead
