Question about Dishwashers
Inlet Water Hi There,Motor etc runs when we turn it on but absolutely no water comes in.I have checked the inlet hose at the tap end,and the tap,and that is all OK.
    Genius:
  • 1,073 Answers
Do you have voltage to the water valve if no then check the float switch if switch is good problen is in the control
if you check the water valve and have voltage to the 2 wires on the valve ac voltage btw then the valve has to be changed
Posted on Apr 24, 2008
Hot water does not come in, only cold water comes in, the water pump works on cold water does not start on hot water
There are no water inlet pumps on standard washers- the water, both for hot and cold, is fed in simply under 'mains' pressure.
(The following is pre-typed for hot and cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 08, 2011 | Magic Chef CAV2000AWW Top Load Washer
Hi i have a lg tot loader washing machine model number wtf652a,the problem is the machine goes through its cycle then stops and there is a code come up which is IE can anyone help?
Absolutely!
LG's 'IE' stands for ' (water) Inlet Error'
John C
Sep 18, 2011 | Washing Machines
Zanussi Jetsystem IZ16 - When starting the cycle the machine will allow a small amount of water to enter the machine, but then it "freezes". I can pause the machine a skip to the next function,...
Hi from retired Englishman in SW France! You certainly do not want to be buying white goods in France- shocking prices aren't they?!!
When you say filters does that include those in the water inlet hoses? Just in case not (following pre-typed!) :-
John C
Sep 06, 2011 | Washing Machines
The washer starts and water runs for about 3 seconds and then stops. i can hear the motor run like it is running but no water. it goes to spin like normal. i have a cabrio wtw6600sw top load
John C
Jul 13, 2011 | Whirlpool WTW6600SW Top Load
Hi i got a hotpiont wt960 and i'm getting the h2o error. water is coming through the inlet pipe and the pressure is fine. i've replaced the water filter aswell as the pressure switch
Sorry- this is my 'standard' reply to water fill/H2O problems- hope it helps!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jul 07, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a beko eco washing machine about 4 years old when i put it to program 4 or 5 the timer turns a bit put stops i just also just seen there is no water coming in to the unit the water taps are open .if...
If you have checked that the hot water tap is turned on fully and the hose is not kinked or squashed at the back, it is worth while checking the hot water inlet filter. Turn the tap off and remove the hot water hose at the washer end. Inside the inlet port there is normally a little filter which should just slide out. Clean if necessary and replace it and the hose.
DO ALL THE SAME FOR THE COLD WATER INLET/ FILTER.
If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve or a malfunctioning control board. Sorry but then it's a service call ;-0(
John C
Apr 21, 2011 | Washing Machines
Whirlpool front loader AWM6145/3 1450 RPM DURING THE WASH HAS COME UP WITH FH. WHAT DOES THIS MEAN PLEASE
'FH' for whirlpool washers decodes as 'no water inlet'.
If you have checked that both hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both of the water inlet filters. Turn the taps off and remove the water hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace them and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve or malfunctioning control board. Sorry but it needs a service call to confirm ;-0(
John C
Apr 20, 2011 | Whirlpool Washing Machines
Fills with water and then stops and beeps and won;t continue. The hot and cold water buttons are flashing. Waterr starts trickling in and it is slowly spinning but doesn't seem to agitate
Hi just read your posting.The 2 lights that are flashing means your machine has not detected any water level difference.1st turn off both hot and cold taps and 1st remove the cold inlet hose from the machine end,Put the end of the hose into a bucket and turn the tap on.You should get a good flow of water.If you do not get a good flow of water then remove the tap end of the hose and see if you are getting water out of the tap.Check the inlet filters on both ends of the hose to see if they are blocked.If they are blocked clean them with a brush.Check also the water valve end where the hose connected to the machine to see if this filter is blocked. Once you have water coming out of the hose and all the filters are clean refit the hose and repeat to the hot hose.Now select a cycle and push start.If the water flow is good then the machine will work properly.If you still get slow water even when you have good pressure coming out of the hoses then your water valves are faulty.Please reply on how you got on and for further advice.looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Smartdrive 508 fills very slowly, seems to "time out". To get the cycle finnished we have advanced the cycle.
Hi just read your posting.Is your complete model number GW 508? The fault with your machine is either your inlet hose filters or your water valve filters are blocked or one or both of your water valves are faulty.Turn off the water to your machine and remove the inlet hoses one by one.Check the amount of water coming out of the taps and check and clean the filters,if your inlet hoses have them, at each end of both hoses.Also where the inlet hoses connected to your machine check the filers on the water valves.If all the filters are clean and you still have the problem then the problem will be one or both of the water valves.Please reply on how you got on or for additional assistance.Hope this helps and looking forward to your reply.
Jul 31, 2010 | Fisher and Paykel Washing Machines
The cold water inlet is slow to fill machine but the hot water inlet works fine
Hi just read your posting.Could you please supply the model of your hoover and tell me if it is a front or top loader.The fault on your machine is due to a faulty cold water valve or dirty inlet filter.Turn the cold tap off and remove the cold water hose from the tap end and check to see if the little filter at the end of the hose is blocked.If it is, clean it and put back the hose to the tap and try a wash cycle.Please reply with additional information and to tell me how you got on with the filter.
Jun 29, 2010 | Washing Machines
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
