Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge jb960 f0 fault code - GE Profile Spectra JGBP90 Gas Kitchen Range
3 Suggested Answers
  • 28 Answers
SOURCE: F0 fault code on magic chef gas range
Do not recognize a F0 code only F1-F10. Recommend unplugging and replug.
Posted on Dec 09, 2008
richroth
  • 9472 Answers
SOURCE: Have GE spectra range model
The "F0" fault code implies the Clear/OFF pad is shorted or a touch pad failure. If the code cannot be cancelled, unplug or disconnect the power supply from the range and then disconnect the keypad and then power it up. If "F0" ceases, replace the keypad/glass assembly; if "F0" is still present, replace the main oven control.
I added an image below with instructions how to access the control and glass panel. NOTE: Disconnect the range from the power supply before servicing.
Posted on Aug 11, 2011
What does error code F3 mean?
not sure but here is the tech service manual GE JB960 Technical Service Manual
Feb 19, 2015 | GE Kitchen Ranges
GE washer model PTAN9455MGG won't adgitate and gives an error code F0
hi, this fault could be slipping belt also brushes on the motor try another program see if it does the same hope it helps
regards
shaun
Nov 16, 2011 | Washing Machines
Have GE spectra range model JB960. The F0 button came on. Followed troubleshooting but no success. Do I replace keypad? If so, how? Where do I get one?
Aug 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting error code F0 during oven cool down. During F0 keypad does not respond to clear error, however after waiting several hours error can be cleared. Next use is fine but error reoccurs during cool...
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 31, 2011 | GE Profile JGS968 Gas Kitchen Range
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
I keep getting an F0 error code on both ovens
F0
touch pad, or both.
Dec 29, 2010 | GE WPSF5170W Profile Performance
I have a GE Spectra Profile XL 44 and I get an code F0. What does that mean?
Here is a tip that I wrote that will help you with the Xl44 profile error codes.
Oven Fault Codes for GE XL44 Oven
heatman101
Oct 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Error code - F0
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
F1 fault
Here are the fault code for GE:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Nov 07, 2007 | GE JSP26 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
77 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
