Question about GE 17.9 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
Freezer works, but the bottom of the refridgerator does not keep food cold.
    President:
  • 1,099 Answers
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help
Posted on Jul 28, 2010
Kenmore refrigerator with top freezer purchased about 8 years ago. The freezer isn't freezing food thoroughly and now the refridgerator is not keeping the food cold enough. What could be the problem? ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 05, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore 253 refrigerator/freezer won't stop running on any setting. The food in the top of the refrigerator would freeze unless I partially blocked the vent. I am wondering what the problem could be. i...
I have a Kenmore model 253 freezer/refridgerator upright model. I am getting cold spots in the refridgeration in and near the vegetable drawers on the bottom of the refridgerator. The icemaker works but the water dispensor has stopped working too.
Nov 28, 2010 | Refrigerators
Refrigerator part quit keeping food cold in last day. The freezer compartment has everthing frozen very solid; more so than before and the motor keeps running. Pulled the refridgerator out and cleaned...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Kenmore 65234 Bottom Freezer Refrigerator
Freezer working, but refridgerator is not cold. The fan works.
You most likely have a failure in the defrost circuit. One or more of thee possibilities: Heating element, defrost timer and/or defrost thermostat.
Check these links:
http://appliancehelponline.com/defrostheatervideo.html
http://appliancehelponline.com/referdefrostheater.html
.g_thread_answer { overflow:visible !important; } X Leave your feedback for the Expert! Write a testimonial (150 Characters max) Submit Testimonial Back
Was this helpful?
Rating helps you get better solutions
Somewhat Helpful
Jun 08, 2010 | Maytag MBB2256G Bottom Freezer...
The refridgerator is not getting cold
sometimes when the air flow is restricted cold air migrates back into the bottom of the fresh food side and could freeze the dispenser resevoir which is behind the crisper drawers. Also, just defrosting the freezer is only treating the symptom. Something malfunctione to allow the frost to build up. Either the heater, defrost limiter or defrost timer.
May 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Coil is freezing up
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Feb 06, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
GE 17.9 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Logo
229 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
