I lost the remote control unit and i need to program the channels for catv. how can do it with the existing buttons ?
    Genius:
  • 1,340 Answers
Most of the buttons on your remote should be on the TV too,at least the important ones.Look all around the edges for them,top,sides,bottom.To program the channels,press the menu button and search around for channel searching options,perhaps auto-search or antenna.If you auto search,you can get rid of channels you do not want(I dumped c-span and a couple others)by going to that channel after the search,press menu,and you will have to fish around a little because it slightly varies between brands,but eventually there will be an option to add/delete the channel.The channel button or volume button will allow you to add/delete.
Since you did not list your brand and model number,if you send it to me I could check out how much a new one is.I would guess at least $60 though. Good luck!
Posted on Jul 28, 2010
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
Have a symphonic tv model number wf24t5 and lost the remote... is there any way without the remote to turn it onto game mode
Yes go to menu with the buttons on your TV and go to CATV sometime u can press your channel button until your channels run out and if u keep pressing the channel button it will go into game mode or in other words switch to the RCA jacks in front of your TV
Aug 13, 2010 | Symphonic ST419E TV
Samsung TV model CT 5029V - Lost remote control - AIR/CATV
do you have a menu button on the t.v. itself? if so gain access there
Nov 01, 2009 | Samsung TV Remote Control
Lost codes for v.old universal remote
All universal remotes work about the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | Sony SLV-SE720 VCR
I have no ''tv/catv'' button on my Philips universal remote
You can go here to see if you can get a new factory remote
TV Parts Universal TV Stands DLP Chips ShopJimmy or you can get a Harmony remote that will never go obsolete no matter how many times you change Tv's in the future or add components to your system
Oct 12, 2017 | Philips Magnavox Learning Universal Remote
My Quasar VV8220
According to the manual, follow the steps below to program channels on your Quasar VV8220 TV:
1) Hold the CHANNEL MEMORY Button on your remote in and press the 1 key
(a box will come up where you can shift between TV & CATV --
you will want to be on CATV (for cable channels).
2) Press the 4 key which will change from TV to CATV -- make sure it is
on CATV or if it is already on CATV, press the 5 key.
3) Press the 4 key (the auto set guide will engage and go through the channels).
Hope this is helpful.
Aug 14, 2008 | Televison & Video
Intructions for programming a remote control
I own this remote. Here are the instructions.
1 turn on your tv or catv
2 aim remote at tv or catv
3 while holding tv or catv button press 0 to 9 last ch 100/ent or channel
4 release both buutons when tv or catv changes channel.
note press tv or vcr or catv button first to select desired function
Mar 06, 2008 | Hitachi VT-RM380A Remote Control
Catv
try to purchase a new remote for samsung because all samsung remote is universal to all remote units.and there you can set the program.
Sep 04, 2007 | Samsung TV Remote Control
Remote lost: My TV/VCR Combo only displays 12 channels
Go to http://www.jvcremotes.com/ or any similar site and order the original remote. That way you are sure to get a remote capable of doing whatever you need. The alternative is to keep buying universals until you get lucky and find one that works all functions on that set.
Aug 07, 2007 | JVC TV-20F242 20 in. Combo
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
