Question about Dewalt 2 Hp 4 GAL Air Compressor
Our air compressor TC 196 fills when turned on and then it starts leaking out of the silver hole on the black box. It was fine a few weeks ago and we have a show in 2 days. Help!
  • 36 Answers
It will be a velve, perhaps the tank oneway inlet velve then when the compressor shuts off its hitting the unloader therfor the air in the tank is escapeing, but you didnt say you loose presure.hope this helps
Posted on Jul 30, 2010
97 Lumina.Two weeks ago had oil change.At that time, mechanic stated that coolant was low and discolored. He flushed the system at that time. This past week,my low coolant light came on. Checked tank and...
take the spark plugs out and fill the water up. turn over the engine. see what comes out of the spark plug holes. should just be fuel. smell. you will need some one to turn the engine over and have good charge in the battery. fill the water to the top so it is level. if you see the water go down when the engine is turning. then it could be air or a leak in the head gasket.
Oct 13, 2013 | Cars & Trucks
Air compressor works...rear suspension low...just used air compressor to fill tire a few weeks ago...could this be related? We had never used it in over 8 years...
The air suspension has absolutely nothing to do with your tire pressures. If your rear suspension is low and you can hear the compressor running all the time, it is because you have a leak in your suspension system. You need to get it diagnosed and repaired as soon as possible. If you let it continue, it will burn-up your compressor, then it will be REALY EXPENSIVE to fix.
Jul 09, 2011 | 2003 Oldsmobile Bravada
Autolub oil leaking onto exhaust
Had same problem a few weeks ago myself. Turned out to be damaged gasket between the carb and the carb body. The two stroke oil filled the carb box which then went into the air intake hose and was running out of the frame around the side panel locator hole onto the floor and exhaust. Replaced the gasket and not happened since.
Jan 09, 2011 | Peg Perego Vespa Scooter
My 1998 navigator rear air bags were filled all the way for about 6 to 8 weeks . Just a few days ago they started to go down slowly and now they are all the down and won't level up or do anything. I have...
Visual Inspection Chart Mechanical Electrical
  • Restricted suspension movement
  • Excessive vehicle load
  • Cut, severed, crimped air line(s)
  • Unmounted height sensor(s)
  • Damaged rear air spring(s)
  • Damaged front air spring(s)
  • Open fuses:
  • I/P fuse 6 (5A) and I/P fuse 20 (5A)
  • Fuse 4 (15A) and fuse 15 (50A) in power distribution box
  • Loose, corroded, or disconnected connectors
  • Air suspension switch is in the OFF position
  • Damaged solenoid valve(s)
Go to dealer and have them run self test and provide you DTC codes. Should be 1/2 hour labor time. Report back on DTC, Diagnostic Trouble Codes.
Also, get some dish soap & water mix and pour or brush on all connections, hoses, solenoids, etc in rear first. Look for bubbles for a small leak.
Aug 13, 2010 | 1998 Lincoln Navigator
I bought the compressor about two years ago and used it only a few times. It ran fine a few weeks ago but today it will not start. It is as though it is not plugged in even though the outlet works for...
Is it possible that you didn't drain the air out of it after you used it a couple of weeks ago? If the pressure in the tank is somewhere around 100psi, the compressor won't run until it drops lower. If there is no pressure in the tank you might see if you can wiggle the pressure lever that makes the switch move to turn on the motor - it might be stuck.
Aug 04, 2010 | Air Tools & Compressors
I just replaced the compressor, it has been
sounds like the first leak was not found . Need to bring it back in. And state that you should'nt have to pay again because it either is a defective replacement or the leak was not in the last compressor that was condemed.
Jul 23, 2009 | 2002 GMC Sierra
TC-196 Compressor not working
If you can, return the unit. I think that the compressor is seized or else there is trouble with the motor. Do not wait for the warranty to expire.
If you need more help, post a comment.
Thanks,
TIm
Apr 03, 2009 | DeVilbiss Dagr Airbrush-tank...
Air Suspension service for a Hummer H2 2003
Replacing with new airbags for the Hummer will be expensive because it is not a permanent fix. I Would go with springs. I understand people enjoying the air ride but I promise it is more trouble than it is worth. Compressors have a 100% failure rate. What will happen is the airbag will end up getting a hole or tiny crack in it so the compressor has to work extra hard because it is like blowing up a balloon with a hole in it. Therefor the airbag kills the compressor and you have to parts you have to constantly keep buying. With air suspension there is never a permanent fix. I would recommend going to strutmasters.com and taking a look at the conversion kits. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. And for a very affordable cost. I added the link below so you can check it out. http://www.strutmasters.com/hummer-suspension-parts-s/96.htm Hopefully this will help Good Luck!!!
Dec 17, 2008 | 2005 Hummer H2
Dewalt 2 Hp 4 GAL Air Compressor Logo
61 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
