Question about Ovens
Kenmore Electric range #665.92022101. The oven wont stop heating up. It was set to 350 degrees and got so hot that it burned a hole in the oven mitt when I went to take out the rack. I unplugged the oven and when I plugged it back in even with the oven off ( the display only showing the time) it heated up again. The oven got over 500 degrees and everytime it is plugged in it just starts getting hot. The bake element is not getting hot only the broil element.
  • 15,935 Answers
Did this problem just start?
Was there a power outage recently?
Are you going to attempt repair yourself?
Do you own a multimeter?
Thanks!
Posted on Jul 27, 2010
  • Gene Strote Jul 28, 2010
    Yes the problem just started. No there have not been any power failures. Yes i want to repair myself. Yes I have a multimeter.
We cooked pizza at 500 something popped and now our oven cooks but not right , any ideas
If you have an electric range, look at both the top and bottom elements while oven is cold. Look for a rough spot like a hole in the element. You may have just burned out one of the elements. Sometimes they go bad without any marks. Turn on oven to about 350 and watch the bottom element to see if it gets red hot. Then set for broil and watch the top for the same red hot glow. If either does not glow red after 5 to 10 minutes, that element is bad.
Apr 02, 2016 | Ovens
Gas oven doesn't get hot enough
Good Morning Friend,
I understand that your Frigidaire oven will not heat to temperature if you set it to 350 degrees. I see that you have to set it to 450 degrees for it to heat up, and then turn it back down to the desired temperature. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock and try setting the temperature to 350 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Ovens
Whirlpool gas oven is taking three times as long to cook something,what is wrong?
have you checked with an oven type thermometer for 350 degrees against the setting of 350 degrees,if its off very far then its the oven temp sensor in the upper left middle or right rear wall of the oven thats bad it looks like a small pencil type rod 2" to*' long it merely unplugs off the oven s control panel in the rear,you can test its resistance also to get an idea if it is your culprit,otherwise the oven element could have a hot spot in it and not letting all the current thru to properly heat the element,it will be dis-colored in that area
Nov 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Set oven to pre-heat to 350; won't go above 100 degrees
could be one of 3 problems: missing 240volts and only have 120volts(one leg out)/bad element(chk for "hot-spot") pitted and discolored-it will soon break there/or the thermocouple is bad that senses oven temp
Jul 26, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore oven - Not heating up
Check the BACK of your temperature knob for an adjustment. I was ready to replace my heating elements when I accidently discovered the adjustment. Made the adjustment and no more problems. My oven now stays within 4 degrees of settings.
Aug 25, 2007 | Equipex PZ-330 Electric Single Oven
Ovens Logo
74 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
