Question about Car Audio & Video
How do i remove the pioneer DEH-P4900IB from 98' Dodge 1500? i do not have the DIN tool.
  • 73 Answers
If you stop by any decent audio shop they should have a coffe cup or a box somewhere with spare keys. if its anything like the ford you can pop it open with a bent peace of a coat hanger.
Posted on Jul 28, 2010
Pioneer deh p4900ib my dpeakers wirs are not working none of the what is wrong wit it
Use VOM meter to see if you have DC Voltage coming out of speaker leads. It should go up as you turn volume knob.
May 15, 2014 | Car Audio & Video
I have a DEH-P4900IB, and i need the wiring color codes
If you are planning to install this unit, I recommend using a wiring harness. The harness for your vehicle will come with the color codes on the package. All radio wires are standardized. Hope this helps.
Aug 18, 2011 | Pioneer Car Audio & Video
I have a Pioneer DEH-P4900IB and I need to know what the remote turn on wire color is thanks or can you give me the complete wire chart thanks
remote turn on for amplifier should be blue/white. remote turn on for a power antenna will be blue. using the blue wire to turn an amp on will shut it off when leaving tuner mode.
Mar 29, 2011 | Pioneer DEH-P4900IB
How to integrate the pioneer deh-1300mp into a 96 Dodge 2500 Centurion diesel truck to replace a radio/cassette player.
The simplest way to swap the stock radio out for the cassette player would be to go to a radioshack or bestbuy, normally they will carry a double-din to single-din adapter so that the smaller after market radio fits into the existing location snugly. They usually also carry a wiring harness adapter that will plug right into your dodges existing harness and you can just wire nut or solder & shrink wrap the adapter to the pioneers harness, saves a lot of time and insures everything is where it needs to be.
Normally you can get both adapters for under $15, hope this is helps.
Mar 08, 2011 | Pioneer DEH-1300 CD Player
The instructions for pioneer system is in Japanese
my best suggestion for you would be to look up the user manual on pioneer's website, look for the model number on the front of the deck its usually deh-p4900ib or something like that, hopefully thats written in english for you or if its not so to pioneers website and look up the single din dvd/gps sytems and go through the pages till you find one that looks like yours, good luck.
Aug 05, 2009 | Pioneer AVIC-N2 Car DVD Player
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
How to connect a pioneer deh 15
If you're talking about the DEH-1500 CD deck, then Here's how to hook it up:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
There's also a user manual online at http://www.pioneerusa.com/pio/pe/vgn/images/portal/cit_11221/50136operation_manual_DEH-1500_2002124142426930.pdf
Sep 22, 2008 | Pioneer DEH-1500 CD Player
Pioneer DEH-P4900IB Changing Time and Date
when the radio is off hold the on the left bottom side for about 3 or 4 seconds and a menu should come on....keep hitting that button till the time comes on. use the up down left right to change it and once ur done just turn on the radio...good lucj
Aug 28, 2008 | Pioneer DEH-P5900IB CD Player
Pioneer deh p4900ib. After installing, only the sub woofer works. Why wont any of the door speakers work
Dodges internal amp requires a remote power wire. I tied the exteral MTX amp to the Dodge internal amp and all speakers work.
Jun 26, 2008 | Pioneer Car Audio & Video
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Nov 24, 2007 | Pioneer DEH-P2500 CD Player
Car Audio & Video Logo
136 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
