Question about Kodak EasyShare C330 Digital Camera
Memory card shows filesys error e01510 - Kodak EasyShare C330 Digital Camera
  • 123 Answers
SOURCE: memory card
Did you just buy this card or have you had it working for a while and now this is happening?
From everything i have read about your camera, they won't take a 2 Gig card. A 1 GIG card is the biggest that is compatible with this camera. If the card is new i would take it back to the store and see if they will let you exchange it for a 1 GIG card.
If this just started happening after using it for a while -- it could be a problem with the card or the camera. Try putting in a different card and see if it will let you format that one. If it does you know for sure the problem is with the card. If you keep getting the same message no matter what card you use, i would phone Kodak. But, according to Kodaks own site, 1 GIG is the biggest card that is compatible. Sorry I couldn't be more help.
Good Luck.
Posted on May 12, 2008
SOURCE: Format Memory Card Error
The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
Posted on May 24, 2008
SOURCE: it says the memory card
The Kodak Z612 only accepts standard SD cards up to 2GB. As you rightly point ot the physical charactreristics are identical, its the internal format of the card that defines SDHC.
Standard SD cards use FAT - which has a 2GB limit.
SDHC cards use FAT32 - which has a limit of 32GB.
Stick with 2GB or smaller standard SD cards.
Posted on Jan 16, 2009
leecom72
  • 4806 Answers
SOURCE: I bought my Kodak Easyshare C310 a few years ago
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Posted on Jun 08, 2009
Obertelli
  • 3006 Answers
SOURCE: i have a kodak c310, trying to format the card and
The c310 will only accept SD cards up to 2GB.
You haven't said which card you're trying to use but the symptoms are typical of those encountered if you try either a larger capacity SD card (which go to 4GB maximum) or if you're trying to use a later SDHC (the HC means High Capacity) card. The c310 was designed and manufactured before SDHC cards were manufactured and is incompatible at the basic hardware level. SDHC's will fit inside as they have the same form as SD cards, but your camera is unable to use them.
If you have tried using the wrong card then all you need to do to fix the error is to replace it with a standard SD card not exceeding 2GB. In practice you'll find that your camera may have issues with some brands/models of 2GB SD cards but that it will work fine with any make or model of 1GB SD card. The smaller capacity card will also ensure that your camera does not become awkwardly slow in operation.
Hopefully I've answered your question; all I ask in return is that you return the favour by rating my answer.
Posted on Oct 21, 2009
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
Kodak camera 2 gb memory card will not work
Format it in a PC using a card reader. Then use in the camera.
Aug 10, 2009 | Cameras
Filesys error e01510 formating error it takes pictures and store it to the camara but when i put the memory card the formaten error comes up i buy new memory card and it does the same
Hii
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jun 16, 2009 | Kodak EasyShare C315 Digital Camera
    Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
    Hi ,Welcome
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    I Cant format my memory card
    use a memory card reader and connect it into your PC, let the your memory card plug into your reader and format it into your pc using that;
    Nov 23, 2008 | PNY 2GB microSD Memory Card
    FILESYS ERROR e00100 2.0GB PNY technologies
    try formating
    u get warranty on this and hence approach the point of sales
    Jul 01, 2008 | PNY 2GB microSD Memory Card
    SanDisk 1GB Impact
    r u unable to copy d pics........???
    tell me den i will give u soln
    di tpe of error comes when memory card gets full....n dere is no space for more pics....
    if u r able to copy d pics den copy it and format ur card
    u can format it wid camera or by using external card reader...
    Jun 18, 2008 | Kingston 1GB Secure Digital Memory Card
    Mar 13, 2008 | Kodak EasyShare C315 Digital Camera
    Kodak EasyShare C330 Digital Camera Logo
    62 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
