Hi i am using hpdv6767tx after installing windows 7 my bluetooth driver stoped working.
    President:
  • 2,600 Answers
The DV series laptopis not supported for Windows 7, HP decided the model is too old to support it....however since Vista and Windows 7 share a common platform, try searching for the Vista driver. Make sure to put into the search parameters either a 32 bit or 64 bit operating system. I have a lot of success using the Vista drivers for the DV6000 and DV9000 series laptops with Windows 7.
copy and paste the entire link below to your browsers address bar. Choose the operating system from the drop down menu, search for the driver from the list.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3675083&
Posted on Jul 27, 2010
Dell E5410 bluetooth not ditecting
Hi Ratnayake RM,
your Dell E5410 is a superb machine. I am telling you some ways to fix the Bluetooth issue. , (assuming you're using Windows 7) if the Bluetooth drivers are installed, then you can right click on the Windows Taskbar, select Properties from the pop-up menu, now in the Taskbar tab's Notification Area select Customize..., see/make-sure that the Bluetooth Icon can be displayed on the Taskbar. After that (assuming that it hadn't already been visible on the Taskbar), you should be able to enable/disable Bluetooth from its System Tray Taskbar icon.Head into Device Manager and check to see if the bluetooth drivers are installed. I'm guessing you are using Windows 7, so go to the stat menu, right-click 'Computer' and press 'Manage'. This will open the Computer Management window, from here click Device Manager on the left coloumn. There should be a Bluetooth Radios drop down menu.
If that is there and there are no question marks next to the items, it means the bluetooth drivers are installed and it should be working. You should also see some bluetooth items under the Network Adapters drop down.
If you cant see the Bluetooth Radio's drop down, it may be because the drivers arent installed. If that's the case, the radio should be listed somewhere down the list with a question mark next to it. Go to the manufacterurs website and find the drivers for the bluetooth module and that should fix it.
OR
Have you tried pressing Windows Key+X? It brings up the Mobility Center in Windows 7. Your Bluetooth may be off or something.
Try these ..these will surely help you
May 31, 2016 | Dell Computers & Internet
Bluetooth not working on windos 8
Lenovo do not have Windows 8 bluetooth drivers on their support site.
You could try loading the WIndows 7 drivers (Broadcom Bluetooth Driver for Windows 7 32-bit or 64-bit)
Jul 16, 2013 | Computers & Internet
I have bluetooth headset MM100 but Windows 7 cannot locate drivers for it.
This is a strange question I will explain.
The MM100 is working according the A2DP (bluetooth) protocol.
So windows 7 can not find your sennheiser drivers because there are none.
Windows 7 needs the driver for your bluetooth card. This is either integrated in your computer or you are using a USB dongle.
Through the bluetooth software within windows 7 or a alternate program provided with your bluetooth card you can look for your sennheiser. This is colled pairing.
There are thousends of methods to pair so read the manual of your computer (bluetoothcard or dongle) aswell as the MM100.
Good Luck
Aug 03, 2011 | Sennheiser Sennhesier MM 100 Bluetooth...
Is BW 900 Sennheiser compatible with Windows 7?
according to Sennheiser, it depends on the compatibility of the usb device driver of your bluetooth adapter in Win7 (it is NOT a BW900 problem in their opinion)
as I understand it, you have therefore to by a new adapter and see whether it works with the BW900. Take the device AND your computer to the shop and have them install and pair
Sep 06, 2010 | Sennheiser BW900 Bluetooth Headset
Bluetooth usb micro adapter not working
Check out http://www.sevenforums.com/hardware-devices/156598-bluetooth-initial-configuration-will-not-launch.html
finally I found a solution that worked
May 17, 2010 | IOGear Bluetooth 20 USB Micro Adapter...
Windows 7 is asking for digitally signed driver which cd doesnt have
Assuming you're trying to install the right drivers for your OS (32bit / 64bit), you can google readydriverplus, which just automatically turns off driver signing at bootup - helps with stuff like peerguardian. I used it in Vista and it seems to work fine w/ Windows 7. Just a thought.
And Thanks.
Mar 25, 2010 | Jabra A320s Bluetooth Wireless Adapter
I've been using windows 7 on my lenovo T61 thinkpad the suddenly the bluetooth stopped working- it couldn't discover bluetooth devices or be discovered by other bluetooth deviced. i even tried formatting...
Your blue tooth card looks like not functioning, You can double check, plug an USB external blue tooth dongle. If it works, defenitely internal Blue tooth card is gone
Jan 18, 2010 | Lenovo ThinkPad T61 Notebook
Aser 5738 laptop bluetooth not working on widows 7
You will probably have to look on the net for a driver that is compatible with windows 7 for your bluetooth device. If you cant find one designed for windows 7 you could try a driver made for vista as many vista drivers work for windows 7 devices as well
Sep 21, 2009 | Acer Aspire 5720-6661 Notebook PC
When i install windows 7 in my lenovo y410 the audio drivers r not working and when i try to install the drivers given they r'nt beeing installed
Hi, Please try downloading the latest soundcard driver from the sound card provider and it will fix the issue. I too did the same and now it works for me.
Jul 13, 2009 | Lenovo 3000 Y410 Notebook
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
