Question about Hampton Bay (261025) Dual Mount Ceiling Fan
What does it mean that a ceiling is "not dual mountable"?
    Genius:
  • 1,970 Answers
Mcdevito75 here, Are you sure it"s Ceiling not dual mountable?? if so it means the fan or a shandleire but not both, the weight cannot be supported by the ceiling.
Posted on Jul 28, 2010
The screen is blinking too fast to do anything I am on another computer now how can I fix it?
inputs are wrong. use the proper cable. Set up your video to extend displays. Change resolution.
Mar 31, 2014 | Chief Manufacturing Chief Flat Panel Dual...
Its aimed tward the ceiling and not at me . how do I change the direction of my video cam?
Find the webcam,adjust it while it is in use and there you have it.If it is only showing one color then it is not your ceiling,that means it is not recognized through your system yet and you may need to configure it for your system by going to the start button,then click devices and printers and you should see at the top there is a list of things plugged into either of your ports/connectors,now find the name of your webcam in that list,double click and setup your cam if needed!Hope this helps. -CB
Sep 25, 2011 | Acer Black AX3400G-U4802 Desktop PC with...
I am unable to remove an old hampton bay ceiling fan it is a flush mount about 10 years old. I have taken everything off but i unable to get the motor part off
There are 4 screws on the canopy which is the part that is mounted to the ceiling box . Just remove those screws it will come down . Hope this helps.
Nov 06, 2010 | Hampton Bay (261025) Dual Mount Ceiling...
Wiring Question
No, the way the motor speed control works is different from the way a light dims. If you connect it, it might work for a while, but it will either burn up the dimmer or the fan motor.
May 14, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
What is mountable boot volume
It is a volume ( ie hard drive or other) that the BIOS looks for to load an operating system
Are you getting a message at bootup such as " cannot find a mountable boot volume"?
Nov 17, 2009 | Computers & Internet
PC will not turn on blinking green light on power supply
The green light on power is blinking, it means power supply working in main power and the main supply not constant that time after constant the green light, then turn on the PC.
Thanks
Aug 13, 2009 | Intel SR1350-E Server Chassis...
No outlet box in ceiling, it has a hook is there a special bracket, my home was built in the 1940s and the ceiling fan in the kitchen was hung with a hookin the ceiling, there is no electrical outlet in...
They sell brackets at home stores, but I have nailed a 2x4 between ceiling joists & mounted an electrical box at proper height. If you aren't good with electrical, get an electrican to run power for you.
The hanger must be SOLID & the wiring GOOD.
Apr 25, 2009 | Hampton Bay 42 In. Antique Brass...
Non wall mountable samsung tv
Take the feet off. See the manual.
May 24, 2008 | Televison & Video
Menu
Hi paulveldt
Very easy ! Simply go into the menu and look for the subfolder that will either read Mirror or Flip Image. Scroll down to it and press left or right until the image is back to normal.
A mountable Projector can project flat fronted ( on a table ) upside down ( on the ceiling ) rear ( from behind - on a rear projection screen ) and upside down from behind ( from the ceiling onto a rear projection screen )
This should do the trick !
Thanks for using Fixya !
Apr 30, 2008 | NEC VT676 Multimedia Projector
Hampton Bay (261025) Dual Mount Ceiling Fan Logo
493 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
