Question about Easy Heat Water Pipe Heating Cable
Pipes in stables freeze - Easy Heat Water Pipe Heating Cable
  • 349 Answers
Run a heat trace line along pipe and insulate to limit freezing. You can check a plumbing or electricial supplier for these supplies. You will need to tell them type of piping material for the right application for your water piping.
Also get some insulation used in unheated areas for more protection.
Posted on Jul 28, 2010
Testimonial: "excellent. But still wondering what a heat trace is!"
  • 39 Answers
It is a cable of a specific length you must specify which plugs into 120V, often has a build in thermostat (recommended) and heats up. Randydm12 has given good advice.
Posted on Jul 30, 2010
Testimonial: "Thank you. Now I know. And also kind of you to say that the previous advice was good. Very reassuring."
Goodman ez-1425 ac copper pipe keeps freezing up
copper pipe freezing on the outside indicates that there is liquid evaporating in the space created by the suction of the compressor
the pipe normally will be insulated to stop atmospheric humidity condensing on the pipe
Suggest that you get in a technician to check gas pressures and ac operation
Aug 06, 2016 | Goodman Heating & Cooling
Tip
Staying in hot water
With water rates on the rise, it is costly letting water run at a remote hot water faucet. It makes more sense than ever to insulate exposed hot water pipes in the basement with the foam insulation that's split lengthwise.
As an added benefit, freezing pipes can be avoided during power outages. The hot water pipes freeze sooner than the cold water ones because the freezing point of heated water is closer to 32*F than the freezing point of cold water. Cold water has a depressed freezing point due to dissolved minerals from municipal water treatments. Water that's been heated has fewer contaminants, hence less freezing point depression!
on Feb 28, 2010 | Washing Machines
How to reset a freezed tablet ZTE v72
If the tablet is unplugged and the rechargeable battery either removed or allowed to run out of power the device will power off. After reconnecting battery / power and booting up the next time recommend to do all updates to hopefully make the operating system stable and prevent freezing up.
Jul 23, 2016 | Tablets & eReaders
Do i need a certificate to freeze pipes in a commercial property
most likely on a commercial property, they must be licensed and osha certified. depending on the state you live in.
Oct 15, 2014 | Cars & Trucks
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
If i insulate my pipes, will it stop them from freezing the water? This problem has been happening a lot this winter, it is colder than usual where I live.
Insulating your pipes won't stop the water from freezing but it will take a much longer time for the water to freeze, so it defintely helps a lot. I would do it if I were you.
Jan 31, 2013 | Insulation
Can you wrap tape around pipes
Yes, you can use heat tape on pipes UNLESS they are plastic or PEX. Copper lines - no problem.Heat tape is used to keep lines from freezing, and generally they do a good job at it, IF you get it wrapped around the part that usually freezes. BUT please understand the design purpose of heat tape before using! For example: My kitchen has an overhang that extends about four heet from the foundation that the water lines run through. In -30 F weather, my water lines will freeze up. I initially wrapped heat tape on the lines below the sink and still had freeze up. So I relocated the heat tape to the crawl space and wrapped the pipe as close to the foundation as I could. That solved the problem.
Nov 29, 2011 | Easy Heat Water Pipe Heating Cable
How hot does the ADKS-400 get can you run inside a pvc pipe?
it doesn't turn on until a freezing temp is reached and shuts off at when temp increases above freezing point. yes it is safe
Feb 14, 2011 | Easy Heat Water Pipe Heating Cable
Water pipe feeding this froze, pipe was repaired, unit filled with water, no leaks won't agitate something smells hot or burnt, vibration low noise comes from unit, won't pump wter from tub
remove the water pump. it may be broken by water freezing iside. also make sure you dont use the washer if ambient temp in room is below freezing. freezing will damage water valves,pumps and freeze grease inside the gearcase.
Feb 05, 2011 | Roper RAS8445KQ Top Load Washer
Mustang 2007 air conditioning is freezing pipes
Check the freon level, too low of pressure in the low side can cause freezing
Feb 28, 2009 | 2007 Ford GT
Easy Heat Water Pipe Heating Cable Logo
183 people viewed this question
Top Easy Heat Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you an Easy Heat Plumbing Expert? Answer questions, earn points and help others
