Question about Dell Inspiron 1501 Notebook
My video on dell inspiron 1501 flashes on and off on the screen, Hooked up external monitor and it works fine. What do I need to look at
  • 3,940 Answers
Try reseating the video cable and ensure the cable is chafed where is passes thru the hinge assembly. If no change, then the LCD will likely need replacement
Posted on Jul 28, 2010
Dell Inspiron 1501 - black screen periodically
Hi,your problem could be as a result of a bad screen or screen connector(Flex)have a technician look at it.
Jan 02, 2010 | Computers & Internet
LCD Screen Repalcement
thats the screen problem u should change the screen than it gonna be alright,
Oct 10, 2009 | Dell Inspiron 1521 Laptop
Blank Screen. Dell Inspiron 1501 ¿?
#1 Tighten the screws for the Display Hinges (The LCD grounds through the hinges)
#2 reseat the display connector to MB
#3 replace display
Sep 14, 2009 | Dell InspironTM 1501 Notebook
Dell Inspiron 1501 LCD flashing colors,works fine on external
Have you updated the video driver?
If yes but problem persist I suspected it's your LCD screen is faulty and needs to be replace.
If your machine is under warrantly no need to pay any fee for the replacement of the part.
Jun 02, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Dell InspironTM 1501 Notebook
Dell inspiron 1501 push power button no screen or sounds
Have you hooked it up to an external monitor? If you can see windows booting up on the external monitor then u may have a bad lcd screen or inverter or video card? Still lots of questions to ask.
Apr 11, 2009 | Dell Inspiron 1501 Notebook
Dell Laptop E1705 Screen goes Blank
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is have the LCD panel replaced. The ribbon cable that plugs the LCD panel into the motherboard could also be the culprit. Here's a link to the display assembly for 1501: http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Jan 09, 2009 | Dell Inspiron 1501 Notebook
I get pink spots on my laptop
This is known as bleeding in LCD .you can try to update video drivers or try to connect external monitor (any normal desktop monitor) and see if same thing happens on external monitor then most probably it is the video card if on external monitor works fine then it is issue with LCD .if system is in warranty then get in touch with dell support
Let me know if this helps
Regards
Sep 14, 2008 | Dell Inspiron 1501 Notebook
Dell 1501 Laptop- 2 inch vertical bar on screen
The easiest thing to try would be rolling back the video driver. Go to Start>right click my computer>click properties>click hardware>click device manager>click on the + next to display adaptor>right click on your adaptor>click on properties>click on the driver tab. Then click on roll back driver and follow directions. If this solves your problem please rate this as fixed. If not, don't rate and add a comment letting me know what happened. I'll always be glad to help you further. Thanks.
Apr 24, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
90 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
