My daughter has a visio e320 va ldc hd tv 32'' she received as a gift from her apartment complex when she moved in. Can't get the tv to select the language. We called costco tech support where it states on box it came from and they were able to confirm remote works (saw laser thru camera lens) but the tv was not working. Had us test all the buttons on the side. She may not be able to return this if complex won't give her a receipt. Any suggestions what may be wrong?
tvtek
  • 1284 Answers
SOURCE: TV not working with remote from Cox cable/Scientific Atlanta
The cable company should be able to tell you how to scan for the remote code that will work for the TV. The other possibility is to try a Funai or Symphonic codes since they are the same with Sylvania now.
Posted on Apr 18, 2007
  • 749 Answers
SOURCE: Emerson tv remote code
I have ask some help from our friends and they also have problems regarding this type of TV... But try this one
Quotes from friends:
1. "The universal remote that came with my Motorola HD cable box worked fine"
2. chat sessions
3. Chat session find jcut92
My quote:
Ask the vendor for a code, if they don't give you return the TV , it lacks technical support... Believe me or else face more problems in the days to come.
I'm sorry, there's lo luck... Fixya me instead...
Posted on Feb 06, 2008
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
  • 5 Answers
SOURCE: 32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
Posted on Nov 30, 2009
Joe here 3-d tv no picture just sound intermediate bak light visio always lights up no picture back light shuts off mod.bdp-s580
Almost always a problem with bad electrolytic capacitors on the power supply board failing. Look online for videos of bad capacitors on YouTube and you will get an idea of what to look for. $20.00 worth of parts if you are lucky and can fix it yourself. I just fixed a 32 and 48" LDC 3D TV this way. Good luck.
Jan 15, 2018 | Televison & Video
How do I get closed caption on my E320 VA TV
Find TV "set up" when pressing the remote menu. This will take you there.
Jul 11, 2014 | Vizio L32 32 in. LCD HDTV
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Fuse locations for Visio E321VL tv
Try to download the repair manual to this set by internet. It has all details.
Aug 17, 2013 | Vizio 32" E321vl Flat Panel Lcd Hd Tv Full...
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
Cannot receive HD signal
TERK HDTVa is a good amplified indoor antenna.
Jan 04, 2009 | Samsung SIR-T160 DTV Receiver
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
232 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
