Question about Juicers
Daewoo juice extractor #DJE330, cleaning basket
I can not remove the basket for cleaning.
ronald_kate_
  • 111 Answers
SOURCE: I need manual to learn how to use it
If you Google your query you will be able to find the manufacturer, they should be able to help you with a manual for this model. I hope this is of some help.
Posted on Nov 05, 2009
SOURCE: OPENING the JC-250 Juice Extractor
I have the same juicer and it works great. I dread the cleanup though. To take the mesh strainer out, you push down and turn the casing clockwise then pull the stainer up. Easier said then done I know but that' how the directions read. The makers forgot to put in, Pull the stainer straight up with everything you have.
Hope this helps.
Posted on May 03, 2008
SOURCE: rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Posted on Jul 12, 2009
SOURCE: Studio UNO Juice Extractor Style CM-400
I just picked one of these up at a garage sale. Could you tell me how to use it? I'm not even sure it has all the parts and have not been able to find it on the internet, except for you and your question.
~Kaye
Posted on Oct 19, 2010
SOURCE: I have a kenmore 09001 800w juice extractor and
Here is the owner's manual:
http://www.juiceman.com/uc/jm400uc.pdf
Posted on Sep 16, 2011
We want to know how to disassemble
Rotate the cover to unlock and remove it and twist off the clutch nut holding the blade
down. Everything should lift off, (blade, basket, and juice bowl).
Feb 24, 2011 | Acme 6001 Juice Extractor
The pulp is quite wet after juicing 2 cups juice. Can you pinpoint the reason?
Let it spin for a 2 or three minutes after juicing. You
can also, slowly, pour a little water down the chute to
leach out more juice and dilute it as well. Also hold
the basket up to the light to see if some of the holes
have become clogged and use a tooth brush to clear
them. If you're using the filters, just rely on the basket
alone, it's not that hard to clean.
Jan 26, 2011 | Acme 6001 Juice Extractor
Cleaning after juicing
It's easy. Scoop out the pulp with your hand and
then under running warm water sponge the outside
first and mop up the inside next. Keep rotating the
basket as you clean. If the juicer becomes discolored
after a while, boil the parts in a solution of Oxi Clean
and water, then scrub. She will look like new.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
How do you open the acme juicerator to clean out the extract
I have a 1962 manual which might be too old but here's what it says: When juicing is completed, simply remove the spring-clamp top, unscrew the wing nut or spring clutch that holds down the cutter blade, and all parts to be cleaned may be lifted from the base. Bowl and top, being non-porous, similar to glass, require only rinsing. Blade should be washed under running water, using a stiff brush. Since the basket is made of stainless steel, it, too, cleans easily. After taking out the the pulp, let cold water run on the outside of the basket while you brush the perforated section. Any remaining particles of pulp will be loosened and can be removed with a damp sponge or by rinsing. Dry and reassemble for next use. Turn machine on and let run a few seconds.
Hope this is of some help.
Sep 02, 2010 | Acme 5001 Supreme Juicerator Juice...
Waring Pro Juice Extractor model #WE100PC - WILL NOT POWER ON!
check bottom of the basket and see if piece is missing or broke.
Sep 04, 2008 | Waring Pro¿ PJC Series PJC11 Juice...
Acme juicer
There should be a lug nut in the center that loosens so you can take the blade, basket & outer basket out to clean.
Jul 26, 2008 | Acme 5001 Supreme Juicerator Juice...
Cleaning
http://www.smallappliance.com/product.asp?pid=9879&cur=USD&sid=18956&mid=34&gid=18975&prdCls=P&shopBy=Category
Jul 12, 2008 | Acme 5001 Supreme Juicerator Juice...
Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
May 13, 2008 | Juicelady JL500 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Juicers Logo
685 people viewed this question
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
