Question about Samsung A177 Cell Phone
My Samsung phone won't turn on..I plugged it into the charger and the screen keeps flashing the AT&T logo. My Phone is the Samsung A177 GoPhone
  • 268 Answers
I would highly recommend u to change the battery and see what happens. Take it to the shop where they sell the battery and only pay for it if it turns ur phone on.
Posted on Jul 27, 2010
Mine is doing the same thing, did you find a solution?
Posted on Jul 30, 2010
My phone has turned itself off,& won't turn back on, whether it is plugged in or not. Any idea why?
sounds like you need a new phone but id take it to a where ya bought it and see if a different battery fix's problem. ive had a battery that would discharge all its juice at random and had that burn up a motorola. hope this helps
Oct 26, 2012 | net10.com
Tip
How to unlock Samsung A177 goPhone
To unlock the network of your Samsung A177 goPhone, please follow the steps as outlined below.
1. Power off phone and then remove SIM card.
2. Turn on the phone again. Do not put back the SIM card. It should say "Insert SIM card".
3. Type #7465625*638* followed by the 8-digit unlock code.
*The unlock code can be obtained from your phone provider. You just need to present them the IMEI code.
4. After entering the unlock code, press the key #.
5. If the unlocking was successful, the phone should say “Network Lock Deactivated”.
on Jan 17, 2010 | Cell Phones
Locked samsung a177.My gophone has a passcode that I don't have the code for so I can't unlock it. I have the imei# 354331/03/572897/2...thank yuu
try this and tell me if it works!
if you just want to do a master reset to change you security lock code enter *2767*3855#
Sep 16, 2010 | Samsung A177 Cell Phone
How to unlock a samsung a177 sim
How To Unlock Samsung A177 1. Turn on your Samsung mobile phone without the SIM card in.
2. Type #7465625*638*
3. Now enter your 8-digit unlock code
4. Type #
5. If worked, phone should say “Network Lock Deactivated”
6. Your Samsung phone may automatically reboot at this point.
Once you finish the above instructions you should have yourself a completely unlocked Samsung A177. Enjoy!
Aug 26, 2010 | Samsung A177 Cell Phone
Samsung Intensity Wont turn on.
More often then not its the battery even tho the battery is fully charged as it may seem. The rel test is get a new battery not your friends battery tho but a new one put it in there and let it charge. If that doe not work then the phone's logic board has been effected and it may or might not be worth reviving. But check the battery first.
Please do be considerate and leave ratings and feedback for all experts involved in helping you out today, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Motorola Mobility Boost i415 Cellular...
WIll not turn on. Screen just flashes the samsung logo when I plug in the charger. Does anyone know about this problem?
problem can be solved.Did you download any application from the internet?.If yes, that means the phone memory is dead and it needs to be flashed to restore the memory of the phone back.You can use this link to Get info. about flashing the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm).
You can also check for the battery may be it is not well charged because the cell of the battery might be weak and needs to wake up by much charger.
You can also get another battery to test the phone to be sure it is not the battery.
You can check both the battery and the board to be sure of wish is faulty.
Take care.
May 21, 2010 | Samsung M320 Cell Phone
I have a samsung f480i.. and lately it just died, when i plug it into the battery charger, all it does is keep flashing the samsung logo and gets extremly hot, it doesnt even turn on anymore, just flashes...
If the cell phone senses that the charging is too strong (that is, if the charger is giving too much voltage that could make damage) the cell phone will react with a message tha tcharging is wrong or by blinking until you remove the overcharging item. Also, it could be that the battery is shorting (internally) and causing the charger to react toa short and the cell phone sense this as incorrect voltage, and thereforeis warning that something is wrong. Try the charger problem by attaching the cell phone to someone' elses phone charger and see if it continues, or if you have or can cheaply buy a car charger adapter for the cigarette lighter outlet; this will tell you if the wall electric charger is at fault or it is the battery.. if you still get the same results with the car charger, hopefully you can go to a cell store or a friend and try another battery before buying one. If a different battery does not stop the blinking, the problem is the phone.. if it is ithe phone, try turning off the phone and wait one minute before turning on.
Apr 28, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung a177 bluetooth help??????/
I'm sorry buddy because there is no way for your phone to pair up with other BT capable phones because eventhough the phone has bluetooth, it is only capable of pairing up with a bluetooth carkit & bluetooth headset.
The SGH-A177 does not have a File transfer profile (FTP) under the bluetooth profiles that ur phone is supporting.
U need to have another higher model but call Samsung first to inquire if the other Samsung phone you want to buy has a file transfer profile.
check this bluetooth article.
that info is straight from Samsung....
Dec 16, 2009 | Samsung A177 Cell Phone
Phone screen flashes when plugged and wont turn on if not plugged in
what is the one you are plugging in..a charger?if that so that your fon's screen flashes when plug in and doesnt turn on when you will not plug in the charger ,then the problem is 99% your batery.replace it.
Dec 04, 2009 | Samsung Behold Cell Phone
My samsung juke wont turn on. ive charged it several times and still nothing. ive sent it to electronic experts and nada. ive taken th battery in and out and nothing. Ive held the END button on the phone...
Does the Verizon logo flash when you plug it in? I had this same problem. Take the battery off. Plug the phone in. Observe the flashing logo. Put the battery back in. Observe "Charging..." screen. Power on. Unplug. Good to go.
Jun 05, 2009 | Verizon Communications Samsung Juke Cell...
Samsung A177 Cell Phone Logo
315 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
