Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
Everything works fine except will not produce heat. My guess is its the ignighter. I think I can install new one or would it be smart to call service man?
  • calvin7755 Aug 06, 2010
    I am having the same problem. Were you able to change the ignighter or a fuse?
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 16, 2011
Model #ALFRIGLEGLIS152ES Frigidaire gallery series won't heat. It stays on for a while and sometimes cuts off. When you set the time on it and press start all the lights start blinking on the o
Hi Robert Burch - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 12, 2012 | Frigidaire Electric Dryer
Frigidaire gallery series , stop every 10 min. flashing ap , no heat .
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not heat
My guess is you probably got some lint on the ignitor and cause a burnout or a limit to trip. If you don't hear the clicking associated with the ignitor heating up and the flame sensor kicking it off then I would check to see if maybe a limit was tripped. On gas dryers when the limit trips the dryer will operate but simply will not heat up. I have a full page with service manual included HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Frigidaire GLGR331A Gas Dryer
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
May 16, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Everything works except the cooking part/no heating/turntable not turning, help!
hi there,
can you provide the brand and model # off your microwave please?
thanks
Sep 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridgedaire Gallery Gas Dryer no heat
replace ignitor if 120 volts to it and it doesnt glow red. ohm all thermal fuses & thermostats. if ok replace sensor.
Apr 25, 2008 | Frigidaire FGQ332ES Gas Dryer
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
Nov 27, 2007 | Kenmore 73952 Gas Dryer
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
241 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
