Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Hayward H400IDL pool heater. Lights with big
I have a Hayward H400IDL pool heater. Lights with big woosh, almost a mini explosion. Stays lit for about 5 seconds then goes out. Tries 2 more times then gives an IF code.
I have cleaned all the burners and orifices, and changed the flame sensor.
The ignitor is getting 240volts @ 4 amps.
Any suggestions where to go from here would be appreciated.
Thanks
john224
  • 1378 Answers
SOURCE: hayward h100id1 above ground pool heater has
Contact Hayward for a local warranty repair center since it is still under manufacturers warranty. http://www.haywardnet.com/locator/ Be sure to change the reason for search to repair/service.
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: hayward pool heater pilot won't stay on
a short circuit in the heater wire will cause an immediate loss of all flame, pilot and main; check the wiring diagram and make sure your pilot wires go to the PP and PP/TH terminals; make sure the terminals are clean and the connection is good; you are dealing with .320 volts DC, any bad connection drops the voltage below the required minimum.
Posted on Jun 28, 2009
  • 9 Answers
SOURCE: pool heater will not flame
sounds like a flame rectification probelm...look in the manual for solutions
thepool
  • 78 Answers
SOURCE: Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Posted on Apr 23, 2010
  • 16 Answers
SOURCE: H400IDL Hayward Pool Heater.
BO is bypass operation fault and FS is temp.sensor failure. It is recommended that you contact a pool professional to fix this. If you are in the Phoenix Metro area you can contact me at info@wefixuglypools.com
Posted on Dec 29, 2010
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
H400IDL Hayward Pool Heater. Ours is dead. Any suggestions on what we need to do to fix it? FS, BO are our error messages.
Dec 28, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other...
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
May 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
MY HYWOOD h SERIES POOL HEATER DOES NOT LIGHT. IT
are you sure the code isnt FO , which would indicate flame sensor failure.usually can be solved by removing and cleaning fl sensor with fine emory cloth.since htr is calling for heat ,pressure switch does not need adjusting
Jul 04, 2009 | Hayward H-Series 200k BTU Millivolt Heater...
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
199 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
