Question about Intel D865GBF Motherboard
Ram Would the Buffalo DDR2 SDRAM 2 gigabytes work with this motherboard?
    President:
  • 2,351 Answers
Hi roniduncan,
Your Intel D865GBF motherboard does not support DDR2 memory.
The D865GBF motherboard does support.
DDR400, 2.5 V Dual channel and up to four 184-pin Double Data Rate (DDR) SDRAM Dual Inline Memory Module (DIMMs) connectors with gold-plated contacts.
Do not have your manual? Download from this link.
http://support.intel.com/support/motherboards/desktop/d865gbf/sb/cs-008983.htm
Please turn to Page 17 in your user manual. (Memory specs).
Inte D865GBF motherboard main web site.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=948&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Any more questions? Feel free to ask.
Mike
Posted on Apr 24, 2008
Will my motherboard(D945GCNL) support 4 GB RAM?
No. The maximum that your motherboard will support is 2 GBs of RAM. 1 GB on each slot. Refer to this link: http://www.crucial.com/store/listparts.aspx?model=D945GCNL
Apr 11, 2011 | Intel D945GCNL Motherboard
My gigabyte motherboard will support single chip 2gb ram and i have to upgrade my ram into ddr2 533mhz to ddr2 667mhz or 800mhz it is possible for my motherboard
Gigabyte GA-945GZM-S2 - motherboard - micro ATX - LGA775 Socket - i945GZ specifications
  • it looke like the supported RAM
  • Supported RAM Technology DDR2 SDRAM
  • Supported RAM Speed 533 MHz , 400 MHz
  • hope this helps
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory None
  • Chipset Type Intel 945GZ Express / Intel ICH7
  • Max Bus Speed 800.0 MHz
  • Processor Socket LGA775 Socket
  • Max Processors Qty 1.0
  • Compatible Processors Core 2 Extreme , Celeron D , Core 2 Duo , Pentium D , Pentium 4
  • Memory
  • Max Supported Memory 2.0 GB
  • RAM Features Dual channel memory architecture
  • Graphics
  • Graphics Controller Intel GMA 950
  • Memory Allocation Technology Dynamic Video Memory Technology 3.0
  • Audio
  • Type High Definition Audio (8-channel)
  • Audio Codec Realtek ALC888
  • Compliant Standards High Definition Audio
  • LAN
  • Network Controller Marvell Yukon 88E8001
  • Network Interfaces Gigabit Ethernet
  • Modem None
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x Processor ( 1.8 V ) - LGA775 Socket ( x4 mode ) , 4.0 x PCI Express x16 - DIMM 240-pin , 3.0 x Memory , 1.0 x PCI
  • Storage Interfaces Intel ICH7 : ATA-100 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s) , Intel ICH7 : Serial ATA-300 - connector(s): 1 x 40pin IDC - 2.0 device(s)
  • Interfaces 1.0 x Audio - Floppy interface - Mini-phone stereo 3.5 mm , 1.0 x Storage - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Audio - RS-232 - 25 pin D-Sub (DB-25) , 4.0 x Serial - VGA - Mini-phone 3.5 mm , 1.0 x Microphone - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style) , 1.0 x Display / video - IEEE 1284 (EPP/ECP) - 4 pin USB Type A , 1.0 x Audio - Line-out (center/subwoofer) - Mini-phone 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - Line-out (side surround) - RJ-45 , 1.0 x Audio - Line-in - Mini-phone stereo 3.5 mm , 1.0 x Hi-Speed USB - Line-out (rear) - 9 pin D-Sub (DB-9) , 1.0 x Audio - Input - Mini-phone stereo 3.5 mm , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 1.0 x Audio - 4 pin MPC
Apr 09, 2011 | Gigabyte GA-945GZM-S2 Motherboard
Asus p5ld2 deluxe ranlike a champ until I added 2 additional 1gb sticks of RAM itbeeps whenthe power is turned on but will notboot
it doesn't like the ram obviously,
  • 240-pin DDR2 DIMM Banking: 4 (2 banks of 2)
  • Chipset: Intel 945P
  • DDR2 SDRAM Frequencies: PC2-4200 and PC2-5300
  • Error Detection Support: Non-ECC only
  • Graphics Support: PCI Express x16
  • Max Component Density: 1024
  • Max Unbuffered DDR2 SDRAM: 4096MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR2 SDRAM only
  • USB Support: 2.x Compliant
  • make sure you installed the correct speed of ram, secondly if the ram speed is correct take out one sitck at a time, and try to boot, it's possible that one is bad from factory.
  • Jan 01, 2011 | ASUS P5LD2 Deluxe Motherboard
    Can i use DDR2 RAM instead of DDR1
    YES, if your motherboard accepts DDR Sdram, and DDR2 Sdram ram memory. If your motherboard has both types of ram memory slots.
    BUT, you can ONLY use DDR Sdram, OR, DDR2 Sdram.
    You Cannot use both types of ram memory in the motherboard, at the same time.
    (BIOS will only recognize one type at a time)
    NO, if your motherboard does not have ram slots for both DDR Sdram, and DDR2 Sdram ram memory.
    Double Data Rate Sdram ram memory modules, have 184 gold plated contact pins on the bottom.
    92 on Each side,
    http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
    (You can click on the above photo to enlarge)
    DDR2 Sdram ram memory modules have 240 contact pins.
    120 on Each side.
    Sep 04, 2010 | HP Computers & Internet
    Can i upgrade my ram to ddr3 if so what would you recomend .cheers
    Thank you for the clarification sir.
    NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
    This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
    http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
    This is the support page for the Fujitsu Scalio 600 Media Center,
    http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
    Uses either DDR Sdram at 333MegaHertz, or 400MHz.
    (PC2700 and PC3200 respectively)
    DDR Sdram has 184 gold plated contact pins on the bottom.
    DDR2 Sdram has 240 gold plated contact pins on the bottom.
    DDR3 Sdram has the same amount of contact pins as DDR2.
    The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
    This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
    So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
    You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
    Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
    Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
    Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
    'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
    Nov 18, 2009 | Televison & Video
    USB driver 2
    Can you be more precise? You don't need USB driver for this PC...
    Jun 25, 2009 | Gigabyte Computers & Internet
    Motherboard driver
    here all the utility to your motherboard, download in this site: http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2669
    Jun 17, 2009 | Computers & Internet
    Can i use DDR 2 RAM for U8668d ver. 6.1 motherboard of 1GB
    your motherboard uses DDR1 SDRAM PC2100 max. as stated on their website:
    http://www.biostar-usa.com/mbdetails.asp?model=u8668+d
    you cannont put DDR2, but you can expand up to 2GB
    Hope this helps
    Alex
    www.CAS411.com
    Mar 17, 2009 | Biostar U8668D (802700113338) Motherboard
    To extend RAM memory
    No its isnt sorry :(
    Only sdram will fit in the slots. Best place for getting it is 2nd hand off ebay.
    Hope that helps?
    Jan 05, 2008 | Intel 845GE Motherboard
    Intel D865GBF Motherboard Logo
    183 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
