Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I bought an intex saltwater generator used with no instructions. It reads 88. What do I do ? Is that right?
  • 297 Answers
Too much to explain
here is a link to manuals and videos this should help
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
you should read some of my other posts so that this salt system doesn't create problems for you like for a lot of others
Posted on Jul 27, 2010
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
I have set up the intex saltwater system. We have run the salt generator for several hours, however the chlorine reads 0. I have added conditioner (thinking this was the issue), however, everything else...
The short answer is add some chlorine. Clean your cell and assure it is operating normally per you owner instruction. Normally, the manufacturer recommends physical cleaning followed by acid wash. Of course use the usual safety precautions when using muratic acid.
Conditioner? Is that Cyanuric Acid? or is this a sequestering agent for removing metal?
Thanks for your interest in FixYa.com
Jul 03, 2011 | Intex Automatic Salt Water System for ...
I have an above ground pool 18' round 52" deep. I purchased the intex saltwater system. I have had it run everyday for 8hrs a day and the ph is high and reads no chlorine. What to do?
Salt generating systems cuase pH to rise over time so you generator appears to have been working. What is the salt level in the water? Perhaps your pool is low hence no more chlorine generation.
Aug 27, 2010 | Intex Automatic Salt Water System for ...
I bought my saltwater chlorinator from an individual. They did not have the book. It reads 88 is that right? The number stays the same
That # is right for str8 filtering
Setting for chlorine generation you need to
Hold down arrow till it beeps
now hold up arrow till it beeps
while 00 is flashing quickly push up arrow till it goes to the hours you want it to run
Now repeat the arrow sequence
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 30, 2010 | Intex Automatic Salt Water System for ...
I just bought a saltwater system for my 12x39 pool a month ago did start up like book said and pool was fine for a month then the low salt light came on so i put 15 lbs of salt in per instructions kids...
you really should get test strips for salt. Get the kind that reads #'s
Get your pool to as close to 3000ppm as you can. any lower than 27000 and you do not generate enough chlorine any higher than 3600 will taste bad and could trigger high salt alarm 3000 is best
run filter only for a few hours before running generator the salt needs enough time to fully distribute through the pool
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the...
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Jun 07, 2010 | Intex Automatic Salt Water System for ...
My intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Jun 06, 2009 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Intex 3-way test strips
I use my 3 way test strips and copper strip when the pool is not running After 15 seconds the readings are using a bit high. After 3 - 4 minutes the readings are perfect.
May 09, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
127 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
