Question about Frigidaire 24 in. FDBB944C Built-in Dishwasher
My Frigidaire dishwasher has no power. Checked breakers etc. All is fine. Could it be on delayed wash? How is that turned off?
5 Suggested Answers
SOURCE: Washing light flashes on Frigidaire FDB1050REM dishwasher
I'm not sure what combination of these steps fixed the problem but its fixed none the less.
As mentioned above i removed the screws at the top of the door removed the top cover. I disconnected the power connector (white) and reconnected. I removed the latch assembly cycled the latch a few times pushed the connectors on the bottom snuggly on. Reassembled the top and the replaced the screws.
After closing the door...all the lights were blinking?? No No its ok..
Place the dial on rinse only and press dry and start/cancel. This will place the dishwasher in a maintenance mode. It will cycle through all the cycles in a short amount of time.
After all of that it started up just fine. Like i said I'm not sure what part of this process made this all work I'm just putting it all out there and i hope it helps someone else with the same problem...
Posted on Mar 11, 2008
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
gary1121
  • 332 Answers
SOURCE: dishwasher loses power
you have a loose ground wire, the is a wire under neith that is a gound that connets to the frame, check to make sure that the wires in the wire nuts are not broke also, even if they look good they could be broke
Posted on May 30, 2009
  • 128 Answers
SOURCE: Please help me figure out why my Frigidaire dishwaher will not tu
Following is a complete trouble shooting process.
My first guess for you is a stuck float valve. Check below and you will see the process to check.
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If no lights are coming on.
First check the breaker to the machine.
If you have an exposed power source to the machine such as a plug or junction box open the box and check the wiring is intact and not rusted etc. Take care here and shut the breaker off first.
No go so far?
Check if your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not the float valve either?
Check the door interlock latch.
Much like a washing machine a dishwasher will only operate with the door closed (or when it thinks it is closed!). There is a metal tab that engages a switch in the door. This is the same switch that activates as you operate the handle to open the door. If it is misaligned it will not signal the machine that the door is closed and the machine will not operate.
You can check this by overriding the locking tab. Put a screwdriver in the door latch and press the switch. You should see the lights come on and power flow to the machine.
Note: if the machine is in run mode you will get water spraying.
To fix this problem bend the tap to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
OK now you are into electronics.
First is quite simple. Some units have an internal fuse to protect the control panel. Check that first. Take your time and take care. Turn the breaker off.
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary.
Do you have water in the bottom of the machine?
Power is there, lights are one, seems to want to work. Water will come in but will not drain.
A small amount around the drain is normal for some machines. This is held to keep the pump primed in some units. However it should not fill the bottom of the unit. You know what it normally looked like so it if is full then you probably have a jammed float valve as above or a clog in the drain.
Drain clog.
Remove the cover from the drain in the bottom of the dishwasher. They usually lift out or have a few screws holding them down. Simple to figure out just take your time and try not to force anything. Look for a clog and clear if necessary.
Your drain can run either direct to the drain under the sink or to the disposal unit if you have one. The drain can clog at either point.
Check by disconnecting the drain line from the dishwasher where if connects to the sink or disposal unit. Look for a clog and clear if necessary.
Water exits the machine via the drain pump. If it is not operating the machine will not drain. It will fill usually to the point where the float valve lifts and does its job by stopping the machine before if floods your house.
If you have water in the machine to the point the float valve is lifted then drain it out first.
Your machine should be running now. Lights will come on and it will run again to the point where if fills with water and trips the float valve again. If so then check the pump and timer (see also timer below).
Remove the units as per below.
If your pump is belt driven check he belt (very few have belts).
If direct drive switch the unit on and let if run to the drain cycle. If the pump does not come on check for voltage at the pump during the drain cycle. If you have voltage replace the pump. If not it is the timer that is faulty (see below).
OK now your are getting to some deeper issues. Not necessarily hard but only go here if the simple things are OK.
If you are not getting water into the unit but you have lights on and you hear clicking and the timer runs and things are trying to work then we know you have power and the timer is running.
No water coming to the unit.
Make sure nobody shut the supply line off. There should be a tap under the sink on the water supply line to the unit.
Turn the unit on an listen at the base for a click as the water supply solenoid (electric switch) opens. No click?
Check the solenoid. Remove the machine from under the counter. There will be screws holding it to the underside of the counter. You may have to lower the legs to get it out. They turn with a wrench to lower.
Under the unit where the water supply line comes in is a solenoid switch it opens to allow the water to enter the machine. Water comes in under household pressure (it is not pumped in by the unit). Chances are it is faulty. Replace it as it can't be serviced.
Still no luck?
The unit is guided by a timer. The timer tells the machine what to do and for how long. If it fails the unit will stop or jam in one cycle. If you have a physical switch the you turn to select the type of wash cycle check it. If you are all touch control then replace the whole board or machine.
To check the switch open the control panel above and use a voltage tester to see if you have current at each cycle point. Cleaning sometimes helps if not replace.
Hope this helps you. Please rate this tip for me.
Adrian
Posted on Mar 13, 2010
Completely dead
Hi Friend, I appreciate your post!
I understand your dishwasher is not working. Let's try resetting your dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn your dishwasher on. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts. Best regards! - Z
Jul 18, 2014 | Frigidaire FFBD2411NW Full Console...
Can't start dishwasher unless I have it on a delayed cycle
Good Afternoon Leslie,
I understand you are unable to start your Frigidaire dishwasher unless it is on a delayed cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Professional Series 24 in....
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Won't turn on. Frigidaire, precision wash, ultra quiet 1
I have the same issue and it occurred around the same time as your post. Do you think there is a conspiracy? :-)
Feb 28, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Does the Whirlpool Gold dishwasher have a fuse?
The fuse is in the control panel on the right hand side after you open the panels 6 screws.
The replacement fuse kit comes with a wire harness that must be used to prevent the new fuse from blowing.
Jan 24, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Frigidaire dishwasher wont run
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
Feb 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Just had a power outage, dishwasher is dead
althought e breakers apear to be on physcally turning them off and then back on especcially after power flashes(the breaker might of partially tripped, and needs to be reset(possible)
Mar 16, 2008 | Frigidaire PLDB998A Built-in Dishwasher
Frigidaire Dishwasher GLDB957JS0 (built-in)
Door switch had to be replaced. Turn off circuit breaker first.
Feb 27, 2007 | Frigidaire 24 in. GLDB957A - Multiple...
Frigidaire 24 in. FDBB944C Built-in Dishwasher Logo
1,285 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
