Question about Philips SA3125\02 MP3 Player
Charging! My philips SA3125 mp3 doesn't seem to charge very quickly, taking over 5 hours, is this normal or do I have a faulty one? It has been charged several times and always takes at least 5-6hours, maybe more, is this the norm? Please advise
Rtyh syudtyevtbr awehbqerg
Posted on Apr 23, 2008
My Philips GoGear Aria (8GB) Doesn't turn on
Hi poseidonisco,
I would attempt a Repair/Recovery, which will restore your device to factory settings as well as update the firmware and improve functionality of your player.
You can find a lot of valuable information on the Philips Support Site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA3125/37&slg=en&scy=US
After performing the Repair, allow your player to charge for several hours and be sure to practice a regular charging routine. If you have any additional questions, you can chat at the above link or you can reach Consumer Care at 1-888-744-5477.
Hope this helps! If so, let me know by rating this solution. Thanks!
REPAIR INSTRUCTIONS:
Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Aug 07, 2011 | Philips SA3125\02 MP3 Player
It was running and then shut off. It wont turn on and the reset button doesn't do anything either. the computer doesn't recognize that it is attached. It appears to be completely dead. I charged it...
You should try to repair the player using Philips Device Manager. The procedure that you should do is described detailed step by step at the manufacturer's web site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=BE&slg=ENG&sct=PORTABLE_VIDEO_PLAYERS_SU&cat=MP3_AND_MEDIA_PLAYERS_CA&grp=SOUND_AND_VISION_GR&session=20100703194931_66.249.65.15&ctn=SA3125/02&list=aa12_list_partial.html&mid=Link_DiagnosticInformationTool&hlt=Link_DiagnosticInformationTool
At first select the category "communication with the PC" and follow the instructions you get there.
Finally you will get to the state "repair function" and you will be able to hope successful action.
gylacz
Jul 20, 2011 | Philips SA3125\02 MP3 Player
How can i turn on my mp3 SA3115/02?
All support for this player is on next site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA3115/02&slg=en&scy=GB
Read the manual from getting started (page 10):
http://download.p4c.philips.com/files/s/sa3115_02/sa3115_02_dfu_eng.pdf
Install the software from the CD or get a download from the support site.
After that, connect the player to the computer and charge the battery for at least 5 hours on first use.
Once the battery is charged, long press play/pause to turn on the player.
When needing more help, just add a comment in this answer.
May 28, 2010 | Philips GoGear SA3125/37 MP3 Player
Y wont the razor phone charger charge my MP3
Well it wont be compatible with the mp3. even if it does seem to fit into the slot where it charges you still wont get it to charge. also different chargers deliver a different ammount of energy to the device so it either wouldnt be enough or it would be too much. I hope this helps you solve your problem.
Feb 28, 2009 | Philips GoGear SA3125/37 MP3 Player
Philips GoGear SA3125/37 MP3 Player Charger cable
The charger cable is sold by an outside company - Philips can give you the number for that company, or you can order it online.
If you already have a charger cable, plug the mp3 player into your computer - it will charge as long as the hold/lock switch is not engaged.
-Tha Mp3 Doctor
Feb 24, 2009 | Philips GoGear SA3125/37 MP3 Player
Nothing works
Does it say Philips and then go dark? If so, try pushing the reset button. Mine did this yesterday, because I did a complete erase. I had to push the reset a couple of times, then it started working again. I'm back in business, and listening to my songs as I type this.
Is your battery charged fully? Did you let it charge via your computer?
Jun 29, 2008 | Philips GoGear SA3125/37 MP3 Player
Player cannot get connected to computer-Philips GoGear SA3115
Install and run the Philips Device Manager software from the product CD.
Select the Repair / Restore option and follow the on-screen prompts.
This will format the player and repair the firmware.
Mar 24, 2008 | Philips SA3125\02 MP3 Player
Won't charge
I'm having this problem also. I have had it "charging" for at least 12 hours, and the screen still shows the battery filling up.
Dec 08, 2007 | Philips GOGEAR SA6045 MP3 Player
Battery indications
This model suffers from battery faults. Not much you can do except change battery.
If it's still under warranty, take it back.
Nov 27, 2007 | Philips SA3125\02 MP3 Player
Philips SA3125\02 MP3 Player Logo
44 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
