Question about Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos top loading washer is showing "LID" error message but will not unlock, will not reset, just flashes LID message when anything is pushed. I tried unplugging, tried different cycles but no luck. The "lid locked" red light isn't on though so maybe the machine doesn't realize it's locked?
SOURCE:
  • 113 Answers
SOURCE: maytag bravos
You have a broken lid switch, get me the model # and ill post a schematic and part #, thanks Dave www.washermd.com
Posted on Dec 17, 2008
VtToolMan
  • 704 Answers
SOURCE: How to Find Lid Switch on Maytag Washer
The newer top loading washer designs don't use standard switches as was typical many years ago.
Today, these washers use a magnetic switch, and bypassing is not easily possible, due to the logic circuits that monitor the washer and all the various cycles.
For any reputable tech to provide a instructions to bypass any safety feature, would be highly irresponsible and would expose us to legal action by this site and the product manufacturer.
Please understand, providing a way to defeat a product's safety feature is against the law and will remain on the internet for years to come, along with the person(s) that provided it, exposing me and my family to a potential lawsuit - sorry, but I wouldn;t do that for my own family, yet alone some stranger.
Just chaulk it up to new technology, just like seat belts and air bags have changed auto safety.
Hope you understand and find this Very Helpful - Enjoy your new washer and best regards!
Posted on Aug 26, 2009
Testimonial: "I suspected there wouldn't be a way to bypass it, but thought it was worth asking. It'll make laundry take a little longer. Thanks for the help! "
  • 58 Answers
SOURCE: I have loaded my Maytag Bravos and all the lights blink
Check door switch wiring or door switch or control board
Posted on Mar 09, 2010
TheMobilian
  • 8220 Answers
SOURCE: Washer doesn't understand that the lid is closed
Door lock replacement vid and more good stuff
Bonus stuff: Wax motor 101 featuring R11 and Q6 swap out and other cool stuff
Note: both the motor control and the central control has to know that the lock is in place, so the wax motor does 2 things! It locks the door and then sends info back to the central control and the motor control on various models. So the wax motor is crucial. A red wax motor is a new and improved wax motor. What other smart pills have I got? Let see: Neptune washer manuals
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 27, 2010
Jahn27
  • 1554 Answers
SOURCE: The washing machine (Kenmore 80
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch during the drain/spin cycle. The machine, therefore, cannot drain and spin when the lid switch is not working. The drain pump doesn't work because it is directly coupled to the rear spline of the motor. Replace the lid switch to address the problem.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posted on Jan 01, 2011
My 2016 Maytag bravos XL MCT showing error code F5. Is this a simple fix?
Lid lock error. They are explained here:
https://www.searspartsdirect.com/washer-repair/error-codes/maytag-bravos-mvw-top-load-washer-error-codes.html
Oct 12, 2018 | Maytag Washing Machines
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Need to remove the glass lid to get to an area of rust caused by a maytag technician chipping the paint and they won't fix it
Tape the washer lid closed. Using a putty knife, press and unlock the two front top locks. The locks are approximately six and a half inches from the outside edge of the washer
Mar 10, 2014 | Maytag Bravos MTW6600T Top Load Washer
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Lid error message, lid is closed
The lid switch is broken....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 03, 2010 | Maytag Bravos MTW6600T Top Load Washer
My Maytag flash F 51 and ul error
Unbalanced load, open lid and redistribute the load, close lid and press START/PAUSE.
Oct 19, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
314 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
