Question about Toshiba Satellite M115-S3094 Notebook
Why can't I get any video when I connect the S-video output from ny laptop to the S-video input jack on my TV?
  • Toshiba Master
  • 8,073 Answers
Not only must you connect the two physically with the S-video cable, but also divert the laptop screen display to the TV or replicate the laptop screen display on the TV screen.
On Toshiba laptops, you use the Fn-F5 key combination to play with the display. Look at the screen capture from my Toshiba laptop. While pressing simultaneously on the Fn and F5 keys, use the right arrow to cycle through the various schemes. For your case use the 4th or 5th scheme.
Posted on Jul 27, 2010
Connect hp laptop to toshiba led tv using vga and audio jack
hi,
I think you need a headphone to rca adapter. your outputting to an output. the output from the laptop has to go IN to the back of the tv to the input next to where your video input is.
Jul 02, 2017 | Toshiba 46TL963B 46 inch full hd led tv...
Cannnot hear the music from video
you have not stated whether you want to hear the sound on TV or Stereo Receiver..
Here are 2 possible solution for both alternative..
1. thru TV
Your VCR has either 2x Audio (red and whitw ) and 1x Video output (yellow) RCA jacks or a SCART jack on the back side..
you need to connect all 3xRCA jacks to your TV's respective input.(or SCART ) than you will manage to see both video and hear the sound by selecting the VIDEO input on the TV .
2.thru RECEIVER
** you need to connect "Audio Output " RCA jacks of your VCR
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone )
** than just switch to respective mode on
RECEIVER corresponding your RCA connection...
There you go..VCR sound on the
Receiver..
*** pls remember you can connect VCR to either TV or Receiver to listen audio ,not both..the yellow RCA video output connection always goes to TV..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
Nothing happens when i connect my RGB to my TV i have pressed the button on my laptop which enables the external monitor connect but that still dosnt work.......... Also my laptop screen also turns black
The laptop screen turning black is what it's supposed to do.
Make sure your computer has the correct output, and the TV has the correct inputs. Very few laptops have analog video out (like the 3 RCA jacks, or the round S-Video jack), but some newer TVs have VGA inputs (Often blue, trapezoidal shaped plug with lots of pins).
If your TV and Laptop are compatible, make sure you've set the Input on the TV to the correct source. You will need to consult your TV manual for this.
Mar 01, 2011 | Computers & Internet
Tv only accepts signal from the single black cable cannot get the tv to recognize the 2 audio cables and one video cable.. how do i fix this?
Hello
Your Emerson TVs audio format is not stereo; it is mono. Therefore only one audio input will be active. There is a Note give on your TVs manual. I copies it here for your information.
1. VIDEO (IN) jack- Connect to the video
output jack of a video camera or VCR.
2. AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
OK.
Dec 21, 2010 | Emerson EWF2004 20" TV
Having trouble connecting laptop to TV
In general, all you need is an S-Video cable. That will connect to the S-Video output jack on most laptops and connect to the RCA jacks on the TV. These usually run about $10-$15 and are available from many online sources.
If your TV has a VGA input, you can get a male to male VGA cable and connect that way, then switch to the external display mode on the laptop.
Jan 04, 2009 | Computers & Internet
I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Dec 28, 2008 | Yamaha RX-V663 Receiver
I have a aiwa cx-na77, how do I connect it to a tv so that I hear the tv sound on the aiwa speakers
If it has an "AUX" input or any other type of RCA jacks for an input, you can connect the TV RCA audio jacks output to the input RCA jacks of the Aiwa.
That's what you would need.
RCA audio outputs on the TV
RCA audio input on the Aiwa
Just look at the back of each unit and see if it has them. RCA audio jacks are the small circular red and white jacks. They will be labed on each unit what they are for. You need output jacks on the TV and input jacks (but not for phono) on the Aiwa.
Aug 08, 2008 | Aiwa Audio Players & Recorders
Receiver to tv hook-up
Is this a Pioneer receiver? They have the prefix of VSX but I can not locate that model on Pioneers website. It could be because it is an older model and no service information is on the website for receivers older than about 5 years old.
To answer your question I need more information. Do you want to connect the video switching of the receiver to the TV or just want the sound of the TV to go to the receiver? I would also need to know what type of video devices you want to connect and what type of inputs and outputs your TV has.
Most TV's have at least a composite video input, that is the most common type. it is a yellow RCA jack on the back of the TV and will be listed as an "input". That is what would be connected to the video output jack (yellow RCA) of the receiver from the TV for video switching. Then you need video sources connected to the video inputs of the receiver to go to the TV. You also need to connect the audio RCA cables from the video devices to the receiver on the proper video inputs that you have connected. Each video input for composite or S-video has audio RCA jacks (red and white) inputs so you can hear the sound of your video device on the receiver.
If you only want to play the sound from your TV on the recevier, you can use the audio output RCA jacks on the TV and connect them to an audio input of the receiver. This is a very simple way of using the receiver for all the different devices connected to the TV without having to connect everything to the receiver and then always having to have the receiver on any time you watch TV. The audio RCA jacks are always the red and white jacks. you just need to make sure you are using the output jacks of the TV and they are connected to an input jack on the receiver. Then you must switch the receiver to what ever input you just connected the TV to, like the "Video 1" or "Video 2" or maybe "Aux" input.
I hope this helps, but you didn't give much information on how you wanted to connect them.
A good rating would be appreciated if you found this free information helpful.
Let me know if you need any more help,
Dave
Jul 06, 2008 | Audio Players & Recorders
Toshiba Satellite M115-S3094 Notebook Logo
465 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
