Question about Simplicity Vacuums
I have a 6550 that just stopped working. I had the on/off switch tested to find out that it was dead. I replaced it and still the machine does not work. Could the wiring in the handle be bad? How do you test if the motor is still good?
  • Simplicity Master
  • 1,545 Answers
I test a motor by taking an old vacuum cleaner cord with alligator clips on the ends and hook it up to the motor simply bypassing the entire vacuum cleaner. If it runs then I know the problem is not the motor.
Posted on Nov 06, 2013
  • 126 Answers
SOURCE: power head
If you have checked the power delivery down to the powerhead and you have current running to the powerhead, then you likely have a burned fuse. There is a fuse built into the powerhead motor and is usually located on the field winding. This is not easy for a novice to replace and even most professional repair shops will replace the motor. It is possible to replace the fuse if you know what you're doing, but if the fuse blew, there may be a more serious problem, after all, the fuse is there if the motor starts to experience distress and the fuse will blow to avoid any electrical issues. The fuse can blow if something is jammed into the roller and causes the motor to labor heavily. If this is the case, then the fuse can be replaced safely. If the motor is burning out, then a new fuse will just blow immediately after replacement. What I do is take the fuse out and run the motor without it to see if the motor is still viable and replace the fuse if the motor proves to be o.k.
Posted on Feb 08, 2008
  • 4 Answers
SOURCE: Fuse for Kirby vacuum
I would take it into a local vacuum shop but DONT take it to a kirby shop because they will charge way more
Posted on Jul 10, 2008
chrispurs1
  • 372 Answers
SOURCE: dyson dc05 motor cuts out
Check for either voltage to switch or if your not happy or compettant working on live mains.
Switch meter to ohms ensure vacuum is unpluged from mains follow live wire (brown) from plug to exit point on the back of cable rewinder check for continuity shold be dead short if it is check switch if this is ok move to neutral (blue) wire again check from plug to rear of cable winder.
The neutral then goes off to moter again check for dead short,
I think from experience that you will have A break in either live or neutral in the mains lead going to cable winder.
If it is its realy easy to replace winder they come with lead all ready fitted.
If you need one contact me.
http://dysonmanuals.llc.nu/index.htm
Chris...
Posted on Dec 07, 2008
  • 13 Answers
SOURCE: The handle for my Eureka 5993 AVZ was getting very
Had exactly the same problem with my upright Eureka Model 5893 bagless. It almost melted the handle! Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there.
Posted on Jan 30, 2010
  • 67 Answers
SOURCE: dewalt 2gallon corded/cordless vacume...unsed one
Check the battery contacts... a common problem on this model. they are easily bent and prone to corrosion.
Posted on Sep 16, 2010
I have a Bissell 6900 Digo Pro vaccum. Just stopped working. Doesn't go on or off when switch is pressed. I figured switch is bad. Opened machine to find switch connected to circuit board so I am...
Most common vacuum cleaner fault and that of many portable appliances, is internal breaks in the power cord - so check that first and then test the switch. There are also safety features that should be checked, such as thermal breakers or thermal fuses.
A multimeter is necessary.
If the switch is faulty it should be possible to source a replacement from a constructor store which can be soldered onto the circuit board it a replacement board proves unobtainable or too expensive.
Apr 17, 2018 | Bissell Vacuums
How to replace a switch in a kirby sentria vacuum
you need to find your nearest Kirby service dealer as its got a lifetime guarantee and when they fix it for a fee they will go over it to make sure there is nothing else wrong with it.
Jun 26, 2014 | Kirby G5 Bagged Upright Vacuum
I have a kenmore vaccum i changed the power cord for the powermate and still not working the model # 11652512202 it work for a second then stop working
1) test the for loose connection in the power cord terminal tight or resolder
2) test the thermical fuse, for loose or defective
3) test for motor brush, repair, clean, and lubricate.
4) test for bel, loose, worn, or breake and replace.
God bless you
Sep 07, 2012 | Kenmore 28614 Canister Vacuum
Turns off when handle is released
you must clean the contacts and resolder, or repair wires , and test for defective and replace switch.
God bless you
May 16, 2012 | Vacuums
Vacuum was working fine now it won't even turn on
Did the vacuum just stop dead while you were using it? The vacuum contains a thermal-fuse which will cut the power off if it gets too hot. Unplug it and leave to cool for 10-20 minutes and then try it again.
If the vacuum has already been allowed to cool and there is no power, there are many possible faults including the power switch, motor and thermal fuse. In order to determine where the fault is, you will need an ohm-meter / multi-meter.
If you've allowed the vacuum to cool and it's still dead, please post back for further assistance and let me know whether you have any electrical test equipment.
Regards,
BElectric
Dec 09, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My dyson vacuum has no power.
Get an ohm meter (found on basically any multimeter), also called a continuency meter. its the setting that beeps when you have a straight line running from point a to b on a wire.
Unplug the vacuum. Test the cable from the plug to where it goes into the switch.Turn the switch on and test the points at the switch. Test the 2 wires running from the switch to the motor. make sure the 2 wires are plugged into the motor. Make sure the brushes on the motor is making contact with the armature. if they all test good, your motor has blown and will need replacing.
Oct 28, 2009 | Vacuums
Dyson DC04 not working
Have you trod on the cable at all, sometimes the cable breaks inside the sheathing, test by switching on and wiggling cable where it enters machine, if it starts then thats your problem, easy to fix, disassemble switch, cut off and discard 6 inches of cable then reattach the reamaining.
May 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The vacuum stopped running and won't turn back on?
While there's no reset button it's not uncommon for the internal thermal switch to trip to an "open" position. This internal, no-access-switch opens when the motor gets hot, it protects the motor from overheating to the point of failure. Bissell's website states that if the thermal switch is tripped let the vacuumm sit for a half hour and then it try it again.
If it doesn't work you might then try Tech610's suggestions.
Dec 08, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Dyson dc05 motor cuts out
Chris...
Nov 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Vacuums Logo
96 people viewed this question
Top Simplicity Vacuums Experts
Oloyede Monsuru
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
