Question about Panasonic AG-DV2000 Mini DV VCR
Help Please! My AG-DV2000 is showing errors F11, F05..and many others after a wile when I'm playing miniDV tapes, and also do not play DVCAM tapes. I already clean the grease from the position mechanism, but did not help. Please hurry!!! I need to know what to do to fix the problem, I'm a video editor, and this equipment is the heart of my job. Thank you Osvaldo
  • 1 more comment
  • Osvaldo Flores Apr 26, 2008
    Thank you accordianman,
    ribbon cable seems to be okay,
    I had adjusted the link transport mechanism and now I had no error and I can play miniDV tapes, but still can not play DVcam full tapes...
    Thanks again, I appreciate your help
    Osvaldo
  • Osvaldo Flores Apr 27, 2008
    Thanks again accordianman,
    I'll continue trying to make the DVCAM tapes to play....
    Till now, miniDV's are working fine.
    Regards
    Osvaldo
  • BORISVET May 08, 2008
    I have the same problem, same deck, What is the link transport mechanism?
  • 979 Answers
You have signalling errors that come from, more than likely, a bad ribbon cable linking the mechanism to the CPU. Good luck on this as it is a service headache.
Posted on Apr 26, 2008
  • Michael Borelli Apr 27, 2008
    Good show on the linkage alignment. The possibility of it coming out of spec is rare, unless there arethousands of hours on the unit, and then only if there has been a lot of wear on the parts involved. Good luck with the rest of it!...accordianman
Sony 570 dvcam error message 91-143 can you help
Microcomputer and its periphery device error
1: CASSETTE IN
4: Capstan motor/capstan FG
2: Detected speed error
It looks like a bad capstan motor.
Dec 15, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Can the Panasonic AG-DV2500 play 90 minutes Minidv tapes?
the DV2500 will not play LP (90 minute) tapes. when an LP tape is inserted, it will play for 2-3 seconds, and then eject.
Nov 28, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
Problem with playing large dv tapes
I am very familiar with these decks and I repair them. Contact my business Waveform Audio Video, Martinez, California. Email: waveform@wwdb.org
Paul
Oct 15, 2008 | Panasonic AG-DV2000 Mini DV VCR
DVC recorder
The physical tapes are the same size, but the encoding on the tapes are different. Unless the panasonic recorder can play DVcam, you're out of luck.
Dan
May 08, 2008 | Panasonic AG-DVC200 DV Digital Camcorder
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure for the inexperienced.
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
the problem of your player is the mechanism to dv tape slut(not mini dv)...it need to calibrate or to tune up...only can fix this is a qualified technician....
Video won't show up on comp monitor
check your inputs on that machine. there are settings that you need to do. when you put a tape in the minidv, does it play fine? if it does, you need to check your input setting on that machine..good luck
Apr 03, 2007 | Panasonic AG-DV2000 Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR Logo
321 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
