Question about Dewalt 18 VOLT CORDLESS JIG SAW MODEL DC330
I put in the saw blade and it keeps popping out
2 Suggested Answers
  • 4 Answers
SOURCE: Scroll saw problems
sand your #45 #47 and make them rough. They seem to wear down smooth and don't hold.Make sure both meet in the middle do they are meeting the blade both sides the same
Posted on Dec 29, 2010
How to clean a POLE SAW BLADE?
  • The first and foremost task is to clean all the impurities, dirt and tree debris. You can do it with the help of wire brush. To remove the oil residue, brush it with a rag or toothbrush and degreaser.
  • Many people prefer citrus cleaner over oil. A citrus cleaner is a versatile cleaner that can be used for cleaning anything in your house.
  • If you are using any degreaser product, mix it with water in a container and put the blades into the container.
  • Let the blade soak into the water for few minutes, scrub it with a rag, rinse it properly and let it dry or wipe the water from the blades.
  • Disassembling the pole saw is required before you clean a pole saw blade and put the blades in the container. For this purpose, remove blades from the pruner. You can take expert's help for this or unscrew the blade.
  • Put the blade on a table where you would clean the blade and keep the edges facing up.
  • Take a sharpening rod and push it forward only between the two teeth. This will file away the meat and sharpen the blade. Keep doing this for few times until you see the filings being developed on the back side of the blade. Make sure to file all the teeth on the blade.
  • The back side of the blade should be rubbed with a file as well. It is required to remove the burrs from the blade.
  • After sharpening coat, the pole saw blade by spraying oil on it to prevent rust and corrosion.
Do not forget to sharpen the blades with files that fit appropriately in the teeth. Diamond and whetstone files are being widely used for filing. So, this is how you can clean a pole saw blade and maintain it also. It does not take much effort. Invest your time to avoid replacing your favorite pole saw in the future.
Apr 07, 2018 | Crafts & Hobbies
Blade moves to the front and then pops off
1. Make sure you put the right tension. Check tension recommendations on your bandsaw/ manual.
Here's a good article about that. What is Bandsaw Blade Tensioning and Why is it Important
2. Adjust the blade tracking. I suggest you to read this blog for reference. Band Saw Tracking Procedures
Jul 01, 2014 | Delta BS100 Shopmaster 9 Inch Bench Top...
I have put a blade in my Mastercraft reciprocating saw. It keeps popping out. It is the long blade for wood. The shorter one stays in. What is going on?
The mounting heel of the blade has to be the same style and you have o ensure the blade is firmly inserted deep within the blade holder.
Apr 25, 2014 | Saws
Roybi sawzall blade wont go in
be sure it is rite type of blade some are pop in and some have a set screw there are several different blades for these couple different types of tools hope this helps
Mar 02, 2012 | Ryobi 18 V Cordless Reciprocating Saw
Blackanddecker typye 2 recip-saw handi saw cordless ,blade wont stay locked in while cutting keeps poping out worthless to use as soon as u put presure on it pops right out
There is a small ball inside the chuck that sometimes gets stuck on these quick release chucks. Check and see if it is still in there and if it is see if it is stuck. If it is just put a drop of oil on it and keep working it. It will loosen up and you will be back in operation.
Jan 30, 2011 | Black & Decker Cordless Handi Saw
How much water do I put in the reservoir?
The rule of thumb here is to have enough water so that the blade picks it up, cooling the blade, but not so much that it floods the machine. If you lift up the grate, you may see an overflow tube that keeps you from having too much water in the sump. If you don't have an overflow tube, then turn on the saw and add water until the blade picks it up, plus a little more. When you notice that the spray of water is diminished, add more water.
--W/D--
Jan 20, 2011 | Qep 60084A 4Inch Portable Wet Saw
KEEP BRAKING THE BLADES ON MY SCROLL SAW.
chances are you might be trying to feed the wood to fast or your speed is set wrong or the blades are not right for the job.
Oct 24, 2009 | Saws
Blade popping off front wheel
Is the axle tight? Has the tool been dropped to warp the frame? But a quick fix if everything else is OK is to loosen up the axle and put a THIN metal shim on the backside of the axle and then tightening it back down.
Jul 29, 2009 | Makita 2107F Portable Band Saw
Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Jun 09, 2009 | Saws
Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Dewalt 18 VOLT CORDLESS JIG SAW MODEL DC330 Logo
113 people viewed this question
Top Dewalt Saws Experts
Craig Butler
Craig Butler
JOHN LAPIER
Tim Venetis
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
