Trying to print but keep on getting error 200 message when i press select the printer switches off.
    Master:
  • 555 Answers
Error 200 for Lexmark printers:
"Input Paper Sensor was not triggered - Paper may be jammed at the sensor. Remove toner cartridge for better access to jammed paper."
Posted on Apr 23, 2008
  • Matt Jurach
    Matt Jurach Apr 23, 2008
    Have you checked behind the toner cartridge for a hidden jammed paper? If you find nothing in the paper path, the sensor could be bad.
    Good luck.
    *If you find the solution helpful, please rate it!*
  • 4,102 Answers
Hi what is your make and model please then i can look up the error code for you as this changes for each make and model thanks
Toshiba studio 181 error c44
This error indicates that the print count has gone above the limit and it requires service. But, this is not necessarily true. Try the following to reset the count:
Solution:
  1. Switch off the printer first.
  2. Now Power the Printer by pressing 0 and 8 keys (keep pressing).
  3. Then a test mode comes up.
  4. Now Type 400.
  5. Press START (!)(You will get a counter and now you need to reset this).
  6. Type 0.
  7. Press Enter(start)
  8. Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
  9. Now switch off the printer and on it normally.
  10. You should see printer working normally
Resource: Clear Toshiba eStudio printer error message Error C44 call service
Jul 23, 2014 | Toshiba Computers & Internet
Printer working but page is blank after printing
try this select all in the page that you want to print then press ctrl +p it will show you a window in the bottom of that window press print selection it most work
Jun 22, 2012 | Kodak ESP Office 2150 All-in-one Printer
Hi I have a brother mfc 5440cn and it fails to print but comes up with an error 50 message. How can i solve this?
Where does the Error message appear? is it on the printer or the PC.
Try a test print from the printer menu
Press Ink
Press up or down to select 'Test Print'
Press up or down to select 'Alignment
Press menu/set
press black start or colour start
The printer should start printing. If this prints ok then the problem is likely to be with the comms between the printer and workstation
Sep 02, 2011 | Brother MFC-5440CN All-In-One InkJet...
Our printer is flashing Tractor1 tear. We are not able to print nor can we get this to quit flashing. I have tried turning it off and back on still having the same issue. Help?
The "Tractor 1 Tear" message is not a error as such, this is an information message showing the printer is set to the front tractor feed (tractor 1) if you press the button directly under "Tear" the printer should move the paper to the tear possition.
If the pritner is not printing I would recomend checking the following;
  1. Ensure the printer is set to "ONLINE" press the button you should see ONLINE TRACTOR 1 TEAR on the display
  2. Ensure the printer is loaded with paper, press the button under "Tear" the printer should move the paper forward if it is loaded into Tractor 1.
  3. If you are not using Tractor 1, ensure you select the paper path you are using within the menu and move the paper selection lever.
  4. Observer the LCD display for any errors that may be seen when print jobs are sent.
  5. Try printing a menu print on the printer this will identify if the printer will print, the menu can be printed in the following way.
    -Power the printer ON holding down the button, keep the setup button held down whilst the printer initializes.
    -When the printer has finished initializing ensure the printer is OFFLINE
    -Press and release the button to enter the MENU
    -Press the button under "MENU" on the LCD display
    -Press the button under "PRINT" on the LCD display
    The printer should print a menu settings page, if this prints OK the most likely causes for the problem are;
  1. The computer system is not sending jobs to the printer (check the correct printer is selected on the computer system)
  2. Connectivity problem (check cabling, IP Addresses etc)
  3. The wrong printer driver is being used
Mar 04, 2011 | Tally T2240/24 Matrix Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Printing pictures on Kodak Printer dock G610 from Kodak Easy Share on the computer
keeps giving me message "printing error" (prints ok from camera) i have probably messed up every setting by now
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
Printer won't print
  1. first you make a self test print by the printer, for this you first switch off the printer then press and hold the button on your printer, and switch on the printer
  2. if you get the test printout all the characters on paper
  3. now you can find the printer is ok and it is work in good condition
  4. now check the cable connection, if it okay
  5. check the installed printer driver software
  6. for these purpose
  7. re install the printer software
  • If your computer not self printing do as follows
  • now your printer is in trouble
  • clean nozzle, print head, align catridge
  • for these go to printers and faxes, on start menu, click right mouse button on the printer icon, select printing preferences, select maintenance option
wish you all the best
Jan 29, 2008 | HP Deskjet 3845 InkJet Printer
Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Nov 21, 2007 | Epson Stylus Photo R300 InkJet Printer
202 people viewed this question
jasbo
jasbo
