Trying to connect my xbox 360 to internet - Computers & Internet
    Scholar:
  • 103 Answers
This is a very extensive procedure. If you go to microsofts website under XBOX networking support, it will tell you what to do. Sometimes to hook it up to a router, port information must be entered. It is at the link below.
http://support.microsoft.com/kb/908874/en-us
From there, you will have to read the documentation for your router on how to put it in. There is some information here
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=1455f3979bad461e8f7fce27365aed93_KB3765_EN_070207_v1.xml&amsstatsid=2598262
Posted on Apr 23, 2008
I can not get signed in on my xbox
Test the Internet Connection on Your Xbox 360
If you are having trouble connecting to the Internet or the Netflix service follow the instructions below:Test the Internet Connection on your Xbox 360
  1. From the Xbox 360 main menu, select Settings, then System, and Network Settings.
  2. Select Wired Network or Wireless Network depending on how you connect to the Internet.
  3. Select Test Xbox LIVE Connection and agree to Continue.
If the test reports that you can connect to Xbox Live, you have a healthy Internet connection. If the test reports that you cannot connect, seeMicrosoft's Xbox support site for more help.
Need more help?
Oct 06, 2013 | Netflix
Advent k200 wired xbox 360 internet
Make sure that your xbox account is connected to a Xbox live membership. If so go sign out, and then sign back in and it should Work.
Mar 24, 2013 | Advent Computers & Internet
My xbox keeps coming up update now but wont do it if u say no it freezes
Check to see if your xbox 360 is connected to the internet. If your xbox is connected to the internet and still is not allowing you to update check your xbox setting. Sometimes your parental control on xbox 360 can stop you from updating your xbox. If all else fails try to take your hard drive off the xbox and reset your console to factory settings
May 29, 2011 | Microsoft Xbox 360 Console
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
I need to know how i can get xbox live with the ethernet cable
1.Simply connect your xbox 360 to the internet with the Ethernet cable. Go from the xbox 360 to a router or directly to your internet source; internet modem or internet cable if you have fiber optic internet connection.
2. Turn on your xbox 360 and go to the xbox live tab.
3. Go wher it says Join and follow instructions.
You can put your credit card info. or buy a prepaid xbox live card
May 28, 2010 | Microsoft Xbox 360 Console
My xbox 360 wont connect to xbox live and ive tried everthing
things you can do..... first start by connecting your 360 to the router and run a test through the system setting menu on your 360 dash board.... to do this go to system setting menu and select the network setting menu.... after selecting network setting there should be an option to test you`xbox live connection.... this is the first step in trouble shooting.... if your xbox connects to the network or router than the problem may be in the Internet connection.... after you have a connection between the xbox and the router... connect the router to the Internet and run the the test again... if you are connected to the network and the internet but still not to xbox live try doing a system update to update your system with xbox live.... after doing all of these steps you may have purchased and xbox that has been banned from xbox live and will not be able to join xbox live..... a more simple solution is that you may not have an xbox live account and simply need to set one up... this can be done through the xbox or you can go to www.xbox.com and set up a live account... you can also find FAQ's and trouble shooting steps there
Apr 22, 2010 | Microsoft Xbox 360 Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Cant connect to internet using internet stick
The internet stick you have would be a USB device which is not supported by Xbox 360, you can connect to Xbox 360 wirelessly or through a wired connection
One way of connecting wireless internet is through the ethernet cable to a laptop paired with your wireless router, or you would have to buy a Wi-Fi adapter for Xbox 360 which retails around $90.
Since Xbox 360 does not have a software like a PC, it is unable to recognize the USB internet stick you have as a internet connection, it may probably end up showing it up just as a USB device on the system settings menu on the Xbox 360 dashboard
Jan 22, 2010 | Microsoft Xbox 360 Console
My xbox 360 was connected to the internet but now it won't work .test connection and it says not connected. tried another cable still the same. Help?????
Does it say Network Adapter - Disconnected?
You tried another cable and still the same thing? When did you purchase your xbox 360? its a possibility that the ETHERNET PORT on your 360 is faulty. might as well contact xbox support to check warranty status of your 360..
Mar 28, 2009 | Microsoft Xbox 360 Console
X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
Jan 28, 2009 | Microsoft Xbox 360 Console
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
