Question about OKI Electric Industry 520 Matrix Printer
Replace pto bands in 520 model belarus tractor
PTO inoperative.
What's the make & model of your tractor? If this is a garden tractor, it sounds like either the belt on your (I assume) electric clutch is slipping or you have low power to the magnets. If this is a farm tractor, then your pto clutch plate is worn and/or needs replacement/adjustment.
Apr 10, 2016 | Garden
Where can I find a clutch?
clutch for what?? if it is for the mower deck drive,then it is a pto,tractors use pulleys in place of a clutch to drive the tractor,so if it is a pto,then go to ebay and type in the model number of the tractor and then pto
May 08, 2015 | Garden
Ford 5000 pto
i believe the lever is on the left side that operates the pto. on some models it will have a plate stating its the pto, you'll have to start the tractor, and engage the clutch, then engage the pto, and release the clutch. Others you simply engage the pto once you've started the tractor
Jul 17, 2014 | Garden
I have a John Deere garden tractor 420 I was mowing the engine stopped I check the 25 amp fuse it was blown. I replaced it turned the key there is absolutely no power
Im gonna first assume that the 420 you have is the 1986 model and not the 68 model , second this model has hydraulic lift on mower , this model has a electric clutch on pto , I assume that you dissengauged the deck drive before trying to restart , but now if you forgot to do so before replacing fuse it would go again if it's what i think it is , so first disengauge deck second ck fuse again replace if nessacary , start engine attempt to engauge deck if engine dies or it does a short time later, ck your wiring to your pto clutch Look for what looks like a chewed up wire finding none replace pto clutch magnet (or entire clutch if lots of hours on it) also ck out my youtube video on finding electrical faults on lawn tractors this might help ya .
Jun 05, 2014 | Garden
Replace cable
how about a model number. helps up see what kind of PTO engagement system you have... but if it's the upside down J you have to points. one on the deck and one under the dash. find both of those and you should be able to see what to do next
Nov 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
OKI Electric Industry 520  Matrix Printer Logo
157 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
