Engin keeps hunting when idling runs lumpey at 1200 rpm but will rev ok to 6000 problem on range rover 3500 efi 1988 model
    Scholar:
  • 103 Answers
This is not an automotive forum. You posted this in a computer forum.
Posted on Apr 23, 2008
Normal rpm range for 91 Mazda protege1.8 dohc manual trans
Hi Tim, The engine with manual transmission should idle at 700 RPM. Usable rev range is from idle speed to between 3000 and 4500 (usable torque range for maximum efficiancy) but not exceeding the red line of 6000 RPM. Regards John
Jun 07, 2014 | Cars & Trucks
What is the factory Idle rpm for 22re efi engine
I've seen from 500 to 1500 RPM in all the manuals I've been through, depending on the year and application (truck/car). In personal experience, 650-800 RPM is acceptable warm operation range. This will also depend on elevation. Will go up to 1200-1500 RPM for cold starting. I live at about 2000ft and my '86 Pickup 22RE idles at 725-750 like a top after about a 3-4 min warm up @ 1250 RPM if it's cold (<45ish).
May 08, 2014 | 1986 Toyota Pickup 4WD
Car idles at 500 rpm now does not start
Check your igniting system,, and your fuel system
Dec 28, 2013 | 1987 Land Rover Range Rover
Idle up down
hunting or surging ilde. name the 2 RPMS, low and high , is it hot or cold engine this issue.? 400rpm or 1000 or 2000 all are diff.causes.
no year, stated. so cant help.
but ill answer in the generic,
1: the ECU (got a carb,? )
the ecu controls idle speed at all times.
if not , there is a problem (you)
A: air leaks in the induction will make motor race at some point the ECU/ISC loses control. and hunts. trying hard to correct it.
b: egr stuck open idle too low, iSC cant correct it,, bad EGR.
c: engine EFI running way too leak starving for fuel so it hunts for 2 reasons < ISC hunting, and lean does that.
lean is gross power loss and opening throttle bogs the engine.
so is double bad. ISC makes it worse,
all this breaks down to 2 reasons.
1: ISC bad. in some way (gummed up. or restricted inside)
2: bad fueling or air leaks. vacuum leaks.
try answers , the hot cold question and the 2 speeds, of the hunt.
lowest rpm and highest of the hunted range of RPM.
Nov 23, 2013 | Honda Civic Cars & Trucks
Back firing through air intake at 3000-4000 revs
IF the engine runs fine at lower RPM and there is no fault codes appearing then it may be valve bounce from weak /broken valve springs or incorrect tappet clearance or hydraulic tappets that are badly worn and not operating at the high RPM. Check rocker shaft bushes and rockers for wear that will allow the units to fail at RPM. Another thing --if you have points in a distributor then the points may be bouncing from weak spring or the cam for the pionts is badly worn on a worn distributor shaft.
Nov 16, 2013 | 1988 Land Rover Range Rover
I have a hyosung 2008 gt 250 r fi model. when i start the engine,idle jumps to 5000-6000 rpm . i checked the isc selenoid and while the ignition switch off the selenoid long,while ignition switch on the...
This doesn't sound like an electrical problem. It sounds more like an air leak between the carburetor and the cylinder. Air that has not gone through the carburetor makes the fuel/air mixture lean. This causes the engine to run super fast and hotter as well. Check all rubber fittings and seals between the carb and the cylinder. Be sure the clamps are tight and all mounting bolts are tight.
May 11, 2011 | 2008 Hyosung GT250R
Engine speed hunts on idle. Auto trans slow shift.
The fast idle valve is inside the throttle body. Sometimes it backs out and needs turned back in (it's threaded). This will cause the loping idle.
Get transmission filter changed with new fluid. Honda does not recommend transmission flushing.
Sep 17, 2009 | 1988 Honda Accord 4 Door
At idle the engine revs up and down
engine lite on? would ck to make sure there is plenty of coolant in system. low coolant may cause idle hunting. also could have a vacuum leak or air intake restriction. ck air filter
Nov 30, 2008 | 2000 Volvo V70
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
