Question about 2wire 2700HG-B Router (2700HGB)
No light come on and it does not work. Is there a fuse inside or
How do I get inside to check components?
  • 2,632 Answers
Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens. Here you will be able to change the settings
Posted on Jul 27, 2010
Why does 15 amp awning fuse keep blowing?
find the dead short
could be a failed awning motor , cut lead , faulty inside light sockets or wiring to the sockets
Feb 17, 2016 | Cruiser RV 2015 Shadow Cruiser S-282BHS
Tail lights, passenger (front passenger and both rear) windows, inside door lock switch and fog lamps are all not working.
These items are on separate circuits. Check the power lead into the drivers door first. No power, or a broken wire to the drivers door in the hinge area can cause window and door lock issues. Tail lights are a separate fuse as well as fog lights. Check fuses to make sure they are all good. Some vehicles combine low amp draw circuits. The fuse may NOT be labeled for the specific item you are attempting to repair.
Aug 31, 2015 | Cars & Trucks
On a 2007 camry which fuse is for the brake light
Look inside its manual. There should be a diagram there and specify
witch fuse is for what component.
Mai
Mar 29, 2013 | 2007 Toyota Camry
2001 Mazda protege radio and lights in car not working after jumper cable s were hooked up backwards
Connecting jumper cables the wrong wat around most likely has damaged electronic components such as a radio and computer.
Check the fuse box and replace any blown fuses.
If you still have problems then get an auto electrician to fix your car.
Mar 06, 2013 | 2001 Mazda Protege
Blinder, head and tail lights stopped working on 2005 E-250. Need fuse diagram
okay, look under the hood in the engine compartment and in that fusebox you will check fuse number f1-24. this is not like the older cars where it says park lights the newer cars and trucks are more confusing as the park lights run through modules so a fuse for another component can cause lights not to work but this is the fuse for the parklights if this doesnt do it then i would test all fuses in that box and then check fuses in the inside fuse box located on the leftside of the dash, as far as the headlights there are a few fuses that control the headlights one for each light and then one for the main switch these fuses are located inside the cab leftside of the dash fuses are f2-3, f2-10 , f2-25 , f2-31 check these for the headlights, here are some diagrams to help locate fuses.good luck and have a good day,johnjohn2_83.gifjohnjohn2_6.png
Mar 14, 2011 | 1997 Ford Econoline
The air conditioning inside lights and electric windows are not working on my mitsubishi pajero
please try to check the fusible link inside the engine compartment some times the color of the fuse is green or pink plug in type fuse
Feb 24, 2011 | Mitsubishi Montero Cars & Trucks
Can't see fuel indicator
It's fine to start out with 10's, but some of your components may use more than 10 and blow your fuses. But you also have some that use a 7.5 and if you exceed that, when the component reaches the amperage the component won't shut off because the fuse can not be (blown) and open the circuit to cut power. you risk a hazard for burning up the wiring or even the car. It's best to find the right fuse amperage rating to be safe and make sure you keep your car.
Jan 17, 2010 | 1988 Cadillac Sedan DeVille
I've got a Kenmore microwave that just stopped working in the middle of a timed cooking. The model # is 721.69200890. Is there a fuse to change or something like that? Thanks, Roland
If the oven is completely dead, (no light or display) it probally is a fuse problem. It does have a 20 Amp fuse. With that being said, I would stress that a qualified service technician check it out. There are some high voltage components inside and a person who is unfamilar with high voltage components can seriously get hurt or even die if they don't take the proper precautions working with this type of appliance.
Dec 24, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
Low beams
hello i no you said you checked your fuse box go under your hood drivers side near your strut tower their problay is a second fuse box its black some times fuses is on the cover you have to unlock the side of cover lift off on inside of cover will list what is what sometimes left and right headlamps are seperate fuses goodluck
Jul 23, 2008 | 1989 Honda Accord 4 Door
Burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Apr 02, 2008 | Sunpentown 11 in. SR-1330 Electric Cooktop
2wire 2700HG-B Router (2700HGB) Logo
60 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
