Question about Pool & Spa
Bought a used Leisure Bay hot tub and it is wired for 220 and I want to go back to 110. What do I need?
  • 8,404 Answers
Reconsider ... Reconsider ...
My comments are general in nature since you have left out a lot of information to make this answer specific to your model.
What kind of load does this hot tub represent? It is probably heated electrically ... if that is the case, I would guess that the load is at least 50 amps on 220 V, maybe more, possibly less. If you convert to 110, your (amp) load will be at least twice that size! you will have to change the heater and the motor to run on 110, it will just not work as well as when running on 220. You may not be able to run the existing motor and heater on the lower voltage, requiring replacement (if available).
Your tub must be protected by a GFI (rated at 60 amps 220 volts) and the supply wire should be #6 three conductor with ground.
If you convert (if it is convertable at all) you will still need a GFI, it will have to be at least 100 amps and your power wire will be #2. I suspect you will not be able to make the attachment of #2 wire (or even #4, if it is legal in your area) to the tub due to size constraints in the connection box. Go to the store and take a look at these wires on the shelf. Aluminum #2 is the size of your finger and you would need three of them to connect at 110 volts.
220 volt 60 amp GFI at the big box store is about $90.00. Did you get wire with the tub? Is it #6, 3 conductor with ground (red/black/white/green)? Maybe #4? Will it reach your power source?
Unless there is space in your power panel for this large double pole GFI, you will likely have to have a sub panel installed. If you are very clever and skilled at working on power panels, you may be able to do this yourself. I suggest you have this done by a licensed electrician. In any event, I would encourage you to comply with the local codes in your community - which are in place for the protection of you and your family.
Look here for generic information on installation. Look in particular at page 3 of the instruction. http://www.premiumleisure.com/Manuals/nov07/ZSeriesSpaManual.pdf
While the picture shows small wire (for clarity?), it looks like #14 wire to me, in bold print, the instruction says use #6 wire, and it should be copper, NOT aluminum. If it is a long distance from the power panel to the tub, you may want to consider increasing the size to #4 to account for power drop. In this case, you would put a standard 220 V 60 amp breaker in the main panel and run #4 to the GFI in a sub panel that is located at least 5 feet away from the tub. The sub panel should be water tight and be lockable, if out of doors. You could run #6 from the GFI to the tub, if your local code allows.
My friend, just wiring this tub without modification is a big, expensive and potentially dangerous job, requiring expertise, knowledge and patience. Changing the heart and nerve system of this device is beyond the expertise of most home owners, if possible at all. Good luck with your project.
BTW, I am not a licensed electrician, though I do have extensive electrical experience, including installing and maintaining hundreds of power pedestals, residential and commercial wiring and power systems around swimming pools. I am a Certified Pool Operator ... and when the time comes, I would be glad to answer your water maintenance questions.
I do have and did install my own hot tub.
I hope this helps you with your question ... thanks for your interest in FixYa.com. If your found this information helpful, a positive vote would be appreciated.
Posted on Aug 02, 2010
Hello, I recently purchased a used 2004 Dream maker Eclipse Hot tub Modern replacement - Aqua rest AR200. Hot tub came with a single speed motor, tub should have a dual speed motor,
look at the motor for the RPM's listed if it only has one it's a 1 speed
2 speed wires are WHITE is common RED is low BLACK is high
WARNING mixing these wires up can BUR the motor up in just a few seconds with no way to repair =JUNK pictures help me help you !
Jay the pump repair guy longwood Florida
Jan 29, 2018 | Pool & Spa
I bought a used Leisure bay Proshield hot tub and looking for an owners manual
I found a link on Google to download the PDF format. www.thespasyndicate.com or www.SpaParts123.net.
Sep 28, 2017 | Leisure Pool & Spa
Where can i view a leisure bayhot tub manual?
You can find a copy of the Leisure Bay hot tub owners manual on The Cover Guy website. We also have a guide for error codes and information relating to Leisure Bay hot tubs. Leisure Bay Spas Hot Tubs Information
Jun 11, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Balboa spa user manual
Unless it's a 110 tub, you don't. If the system is designed to run on 220 the circ pump and flow pump will not function properly, the power pack may not function and the tub will never reach temp. If it is a 110 hot tub I would still suggest having a licensed electrician run the line for you. Most insurance companies will not cover any type of hot tub related claim unless installed by licensed tub tech/electrician. If you insist on wiring it yourself, the BLACK wire is the "hot" wire carrying the current. In 220 installations the RED wire is the second "hot" wire. The WHITE/GREY is the neutral wire, and the GREEN is the ground. But again, I STRONGLY recommend paying the $80-$95 bucks to have it done professionally. I hope this helps =)
Nov 03, 2013 | Pool & Spa
I just bought a used hot tub with a Balboa Instruments model WL T-Pro motor. The cord from the motor has been cut and the people who set the spa up for me wired the cord into a 220 plug. I don't have a...
There are electric motors that run on ether 110 or 220 but wire must be changed on the motor to change from one to the other. Look on the side or end of the motor housing for a identification sicker or plate it well have the information that well tell you which it is or if it can be either.
Now for the bad news if it was sit up for 110 or if it is only 110 the motor is most likely fried.
Feb 01, 2011 | Home
Does it matter if use 220 or 115... looks like i have 25 amp in the box with gfi.. need connect the wire to back of the motor.. outside i have the big circular 3 pronged connection to the outlet... do i...
220 VAC is more efficient ... so there is some cost savings in the money department. Volts X amp = watts generally ... there is still a savings because you will actually consume fewer watts at 220 (watts is what you are purchasing form the power company)
Wiring depends ...you going to use 110 or 220? if 110 ... black is hot and goes to L1 ... white is nutral and goes to L1.
If 220 ... black is hot and goes to L1 - white is hot and goes to L2.
Your owner manual has a good picture and description of this.
In the plug ... 110 - neutral should go to the left slot.
Is your breaker 110 or 220 (single pole or double pole - one slot or two slots)
These voltages are not compatable!
I suggest you use this pump at 220.
Jun 04, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
120v hot tub wiring diagram! Need to wire fro 120v! there is a red, white, black & green to connect the wire from the power plug. The power cord only has black, white & green. Which is the hot and...
I would expect your tub is either 110 or 220. Currently you are set up for 110. Based on that ... you disregard the red wire.
If your tub can run on 220, you should run it on 220 as this is more economical.
You should probably have an electrician check this out and make any changes to assure proper and SAFE operation of your tub. You are using a GFI, correct?
Thanks for your interest in FixYa.com
May 15, 2010 | Pool & Spa
When we plugged up our leisure hot tub it smelled like plastic bu
SMELL IS USALLY DUST ON HEATER TUBES TO BE SAFE FEEL CORDS AND LOOK AT RECEPTICALE FOR BURN MARKS WHAT TYPE OF TROUBLE WITH OTHER ITEMS
May 24, 2009 | Pool & Spa
Pool & Spa Logo
588 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
