Question about Compaq Armada M700 Notebook
Mouse the mouse that is used on the older pc's like mine that is located in between the G, H and B keys, what is it called and where can I find a replacemnet for it? The padding has worn down and it is a pain to use.
    Scholar:
  • 87 Answers
They are called 'mouse nipples'. Also known as: TrackPoint; PointStick; NX Point; Pointing Stick; Stick Pointer; PointStick; QuickPoint; Track Stick; AccuPoint; FineTrack
At the moment you can buy them on Ebay
Item number: 130216827092 Cost £2.40 for 6, seems they are a standard fit but not sure so could be an idea to email the seller first.
Posted on Apr 27, 2008
Unlock keyboard
This happens when the Keylock on some (usually older PCs or PCs used in corporate environments. Those PC actually fitted with a physical Key lock and usually comes with a small lock and a key. try to locate the lock on the casing. If you can find it just short circuit the two wires and you can access the keyboard. It you can't locate it, it means the lock is removed and you'll have to locate the connector /jumper on the motherboard by carefully inspecting it. It could have some writings to identify it (KYLCK, KBLOCK, KEYLOCK etc). Again short circuit it and try. Do not do this if you are unfamiliar with PC hardware and leave it to a professional.
Hope this helps
May 22, 2013 | Famous Brand Intel Desktop Computer -...
Every time I boot my EEE PC the touchopad is disabled. I plug in a USB mouse, enable the Elan smartpad through the properties of the Elan smartpad and it works ok until I reboot again. How do I enable it...
Usually there is a FN key that will enable the touchpad. I have EEPC and mine is the little blue FN key (usually next to the CTRL and Windows Key) + one of the number keys. Look for a little blue symbol that looks like your touchpad.
As for it being disabled every time you start, I find that very weird. Sometimes installing a wireless mouse, installs software that tells the system to disable the touchpad, so that the 2 don't conflict when using the mouse.
Aug 28, 2011 | Computers & Internet
My cat jump up on my laptop a [compaq presario cq61 model ] while i was emailing and the curser is now frozen, and i do not know how to fix. have plugged in a mouse and this lets me move the curser but...
ur keyboard mouse is locked look where the f1,f2,f3,keys are and find the mouse lock key when u locate it then pressand hold ur FN KEY (usually on bottom left on key board ) and the mouse key to unlock
Jan 30, 2011 | HP Compaq nc6000 Notebook
The arrow cursor ( pointer) has stopped in one place as though it has frozen itself there and it you use the touch pad nothing happens what do i do next
if it works with a mouse plugged in you might have accidently turned the mouse pad off, use FN key and on mine it's F7 to turn it off and on. hope this works for you
Sep 05, 2010 | Toshiba Satellite A60 Notebook
My mouse and key board is not working it's an old computer the mouse just moves in direction .upand down.
Probably a bad mouse, I've had this too. Although, if it's an older ball type mouse it might be helpful to clean it. Remove the ball and locate the two roller pins that the ball operates. Clean off the gunk that builds up on these rollers & causes them to stick. Reassemble and give it a try.
Jun 20, 2010 | Computers & Internet
How do i change the mouse buttons on a compaq 6735s
Are trying to switch to lefthanded settings?
Converting to Left Hand Mouse for Windows XP Users:
  • Call up the Start menu by clicking on the Start button or by pressing the Windows logo key (located between the Ctrl and Alt keys). Alternatively, you can press Ctrl + Esc
  • Click on Settings and select Control Panel.
  • Double click on the Mouse icon to display the Mouse Properties
  • Select the Buttons tab and click on the check box marked Switch primary and secondary buttons to set the mouse buttons up for left-handed use.
  • Click OK or press Enter to confirm your choice and exit the mouse properties (note: you should be using the mouse’s right button now to make selection)
http://www.tipandtrick.net/2009/customizing-the-mouse-for-left-handed-users-in-windows-xp/
Jan 02, 2010 | HP Compaq 6735s Notebook
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
The arrow is frozen on my laptop other than that the pc is working normally
Could be the mouse lock key. I am unsure as to which key it is on yours. Mine is the F9 key. it will have a picture of 2 mouse on , 1 with a no go sign over it (circle with a diagonal line through) try pressing the "fn" key and F9 and see if this unlocks the cursor.
May 23, 2009 | Sony VAIO VGN-FE590 Notebook
Keyboard wont work
ok I don't really have enough info on this question but im pretty confident i can help you.
it sounds like your brother has a desktop computer and its a bit older. so since he does not have usb ports on it it has a pin connector called ps2 its located next to the mouse connector.
all you have to do is go to a store that carries OLDER keyboards maybe even a used keyboard just plug it up (while pc is off) and that should resolve your issue :)
Apr 10, 2009 | Dell OptiPlex GX270 PC Desktop
Print to large on my monitor.
If you are using internet explorer, you can hold down the Ctrl key and hit the - key to make the text smaller or the + key to enlarge the text. If you have a wheel mouse, hold down the Ctrl key and turn the wheel on your mouse, and that will make it larger or smaller. If you can get to the view tab click it then text size, I have mine set on medium. Good Luck.
Mar 11, 2009 | Gateway GT5056 PC Desktop
Compaq Armada M700 Notebook Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
