Question about Raymarine St1000 Plus Tiller Pilot
When I plug it in it reads the degrees but when I press any button it just reads 1000 and the shaft does not move hold down any button and it clicks the 1000 message rapidly. No movement of the shaft of any kind is detected It worked correctly up to now. Anything I can fix myself or does it need to be sent in? using it on a WWP19--2000 lbs.
Same thing happened to a friend using an ST2000+ (was reading 2000 instead of 1000). Found that that power (12 V) and ground had been mixed up, so that the internal reverse voltage protection keeps resetting the pilot each time a button was pressed.
Posted on May 29, 2012
How can I tell what size my cam is on a sbc
attach an angel /degrees disc to the crank shaft. fix a dial indicator to the inlet rocker. turn the crank until the rocker just starts to move. set the plate to read 0 degrees turn the crank until the dial indicator now moves back down. When it has stopped moving read the number of degrees that the crank has turned. repeat the operation for the exhaust rocker. the two readings will give you what size the cam is. of course if the cam is out in your hand the size will be stamped in the end of it.
Nov 16, 2014 | Cars & Trucks
How do i move control panel temperature from 65 degree to lower number
Have you tried a small squirt of WD40 round the knob
May 15, 2014 | Dishwashers
Temp switched from F to C reading?
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
Dec 23, 2012 | Comfort Zone CZ1500WC Infra-Red...
Garage door wont move, I just replaced the worm gear inside. Reassembled everything back together and when I put the chain on, it moves down and stops and gets stuck, wont move up or down anymore. Any...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Jan 05, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Robert Shaw thermostat and it converted to celsius degrees. How do I program it for farenheit???
The thermostat is preset to display the temperature in degrees
Fahrenheit (US models) or degrees Celsius (Canadian models). The
temperature display can be changed. Press and hold both the
?° and ?°Ÿbutton for three seconds. The display will read F or C.
Release buttons. Press the ?° or ?°Ÿbutton to switch the display.
Jun 16, 2010 | Shaw Robert RS-9420 Thermostat
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
The oven is 100 degrees colder then the read out
press bake and set to 550degrees. within 2 seconds press and hold the bake until 2 digits show on display, then release bake. the digits displayed is the amount of degrees the oven is off from original factory setting. If it reads 0, it is at original factory setting. you can now adjust by pressing the up button for a hotter oven, down for lower. it can only be done for 35 degrees. when done, hit clear/off. this will help to close the gap. if you are using an inexpensive thermometer, it can take a very long time for it to read the actual temp in the oven.
Nov 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Skil 2100daf angle finder
I was trying to reset the zero on my angle finder. It's a Powerfist Digital Angle Finder, the same as the Skil 2100.
After turning the unit on, if I press the Miter and Hold button together and hold them, the unit goes into 'calibration' mode. (The display flashes 0.0). If you do nothing, it will always stay in this mode forever after that.
You can then reset your unit - it takes time however and patience.
With the aid of a large protractor, draw angles on a large sheet of paper (I used a couple of 11 X 17" pages) from 0 degrees all the way up to 220 degrees.
Turn on your angle finder and make sure the numbers are flashing 0.0. This will be your 0 degree reading. Hold the finder closed and press the Hold button once.
The display will now read 10 degrees. Open up the finder until it matches your 10 degree marks on your paper and press the Hold button again.
The display will now read 20 degrees. Open up the finder until it matches your 20 degree marks and press the Hold button again.
Continue setting your angles in this fashion up 'til you reach 220 degrees. The next button press will close the calibration cycle and the numbers will stop flashing.
Your unit is re-calibrated. Now, if it's off - you've only yourself to blame.
Apr 23, 2009 | Skil 2100DAF Digital Angle Finder
How I can set the timing on a 1996 Silverado Z71?
An OBDll compliant scan tool is required for this procedure. With the ignition off install scan tool to the data link connector. [found inside vehicle, drivers side below dash] start the engine and bring the vehicle to operating temperture. Monitor cam ****** on scan tool. If cam ****** is between -2 degrees and +2 degrees the distributor is properly adjusted. If cam ****** is not between -2 degrees and +2 degrees the distrubtor must be adjusted. With the engine off loosen the distributor hold-down bolt. Start the engine and check cam ****** reading, rotate the distrubtor counterclockwise to compensate for a negative reading and clockwise to compensate for a positive reading. Momentarily raise the engine speed to over 1000 rpm and check cam ****** reading. If the proper reading is not achieved repeat steps 7 and 8. When the proper reading has been achieved tighten the distributor hold-down bolt and disconnect the scan tool.
Nov 25, 2008 | 1996 Chevrolet K1500
Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
  • There appears to be a shortage in one of your lines to you computer. But, before you replace anything, try these methods.
  • Shut down the computer.
  • Remove any CDs, DVDs or external storage devices (like USB keys or external hard drives) from the computer, if any are present, then press the power button to turn the computer on.
  • Press and hold the <F8> key as your computer starts. You need to press <F8> before the Windows logo appears.
  • If the Windows logo appears, and the system still fails to boot to Windows, shut down the computer and try again.
  • From the Advanced Boot Options menu, use the arrow keys to highlight Repair Your Computer, then press <ENTER>.
  • Click to select your language, and then click NEXT.
  • Log in as a user with administrative rights, and click OK.
  • From the Choose a recovery tool menu, click Startup Repair .
  • Once completed, click FINISH.
  • Click RESTART.
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
Oct 03, 2008 | Dell Inspiron 1000 Notebook
Raymarine St1000 Plus Tiller Pilot Logo
198 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
