I have a Dell Dimension 2400 with an E773c Monitor. I was uninstalling some software and my screen changed to extra large icons and print. I cannot get the slider to reset it to work.
  • 19,396 Answers
Change display properties
Posted on Apr 23, 2008
  • 1 more comment
  • Ginko
    Ginko Apr 23, 2008
    Click the right button of mouse on any empty space on your desktop, a drop down menu will pop up.
    Chose last option , which is properties.
    a display properties window will pop up
    On display properties window chose last tab on top right hand corner, which is called 'settings'.
    From settings change display resolution.
    Regards
  • Ginko
    Ginko Apr 23, 2008
    typical settings are 1024 to 768
  • Ginko
    Ginko Apr 23, 2008
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
What is the biggest wide screen monitor can I get to use with the Dimension 2400 and the integrated video?
The monitor (19-inch, non-flat screen, 0.24 dot pitch) presented a more than acceptable image, even at its maximum supported resolution (1600X1200 @ 75Hz). We settled on a more reasonable 1280x1024 @ 85Hz as our preferred setting. According to the documentation, the recommended resolution is 1280x1024 @ 75Hz .Many of the newer LARGE monitors are limited to 60Hz and/or a larger dot pitch...So..look for a low dot pitch(below 0.27) and the ability to run at 1280X1024@75Hz . Passed that, the size is up to you.
Nov 18, 2009 | Dell Dimension 2400 PC Desktop
My screen is white an cant find icons help
Can you access the monitors in built menu? If so adjust the brightness control to see if that helps. If not try another monitor, as I suspect that the monitor is at fault.
Oct 31, 2009 | Dell Dimension 2400 PC Desktop
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
I reinstalled XP on my Dell. How do I get the e773c monitor to work. It uses default monitor software. The CD that came with the system has no setup icon. I donloaded a driver but the download has no setup...
you can format the system bt any document save on the system vanished as you do,if copied any useful document into removable devices, then you can now get the software in the software market and reinstalled it to the system.waith and see it work.
Jul 09, 2009 | Dell E773C 17" CRT Monitor
Computer hangs during boot up after instlaling lexmark 6650 print
This is a problem I've seen with Dell PCs, what it is doing is trying to boot from the card reader on the printer. My PC had this problem, and a Dell BIOS upgrade fixed it. It would even try to boot from USB keys or mp3 players I left in the USB slot! So I have a feeling you have the same problem I had.
If you don't feel comfortable updating the BIOS, then contact Dell and maybe they can walk you through it.
Mar 30, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
E171Fpb driver on dimension 2400
installing windows again then the monitor driver should resolve the problem
Jun 25, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
