Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
No Spin Cycle
Spin cycle fails to operate on all washing cycles. "Door Locked" light on. Clothes dripping wet after wash cycle completes. "Max Extract" fails to function also.
  • 1 more comment
  • Anonymous Mar 17, 2014
    wash and spin cycles won't start due to door locked red light staying on
  • Anonymous Mar 23, 2014
    Lint on clothes after washing cycle complete
  • Anonymous Mar 24, 2014
    max extract does not seem to be working
    Champion:
  • 207 Answers
Your machine won't go into spin cycle most probably because it awaits for pump to start extracting water out of the basket. If the "Door Locked" light is on th an it means that either filter, pump or drain hose are clogged (unless pump burned). Turn off machine, unplug the machine, clean the filter, check for foreign objects inside filter and pump housing and finally check/unclog the drain hose.
Posted on Apr 23, 2008
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Posted on May 26, 2008
My Kelvinator K600 Washing Machine sometimes does not operate on the Spin Cycle
Spin clutch soliniod not engageing underneath (replace).
Oct 02, 2016 | Washing Machines
New washer- WTW5000DW0 / C43742143 clothes not spinning
are the clothes very very wet ? is the machine emptying properly? you could check that the pump isn't blocked or partially jambed I'd start at the pump first, barring that it could be the main program controler
Nov 30, 2014 | Washing Machines
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
503 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
