Went to Dish Network for my new TV sometime ago. Immediately VCR would not work. Lots of advive... Looked at Amazon today for new VCR. Read a comment on one...Had to get a modulator to use Dish Network. Maybe this is my problem?????? Thanks
  • 3foster3 Jul 27, 2010
    Don't know yet
  • 10,865 Answers
Hello.
I personally use the Dish and I have installed several. Your best bet is to buy or lease the DVR that the Dish offers. It has lots of wonderful features and is fully compatible with the Dish remote. Just call your Dish provider and check it out. You will be glad you did. J.
Posted on Jul 27, 2010
How do I find Amazon prime on my dish network?
amazon prime isnt on dish network. You have to use either your cellphone to cast it to your tv, or get a device like amazon firestick for your tv.($30)
You then have to log into Amazon to access the video stuff.
Jan 28, 2018 | Amazon Computers & Internet
Connect dvd/vcr to HD-tv via dish network
Hey my nameis Mike Houston of DISH Network and I see where you want to run the SanyoDVW-6000 DVD/VCR Player to the DISH Network receiver. You can run the SanyoDVD/VCR directly to the TV and pick the channel you want to record and it willrecord the channel showing.
Dec 07, 2010 | Sanyo DVW-6000 DVD Player/VCR
I have Dish network. I want to record TV onto the VCR, but cannot get channels to record. i can playback videotapes and the record works, but cannot figure out how to get the signal to record.
The output of the Dish Network box should be hooked to the input of the VCR.
The output of the VCR should be hooked to the input of the TV.
The VCR should be on channel 3 to record. Select channel to be recorded on the Dish Network box.
It sounds like you have Dish Network box output hooked to TV input.
& VCR output hooked to an aux. input on the TV.
Nov 28, 2010 | Quasar VHQ401 VHS VCR
We have dish network with a dvr. A few weeks ago it started recording things we did not program it to and deleting timers that we had programmed. We called dish and they sent us a new unit. Immediately...
Hello, my name is Becki Barned with Dish Network customer service. I understand the frustration with this issue. There are a few things that could be causing this problem. There could be interference with a remote at a location near yours, such as a neighbor's remote. It could be a grounding issue, in which case a technician would be needed. Since it is happening on the second unit, a technician may be the best resolution, because as I said, it may be a grounding issue causing this. If this has not yet been resolved, or you have any other questions/comments, blog back, or you can also find us on Twitter!
Nov 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Problem connecting DVD/VCR to DISH
Dish dvr can only output so you have to connect your dish dvr to your dvd/vcr and then connect your dvd/vcr to your tv and im sure it should work
Dec 19, 2009 | Televison & Video
Nothing works
Mamarene, you should have a cable that comes from the flooor or wall that will got to the Satellite in port on the Dish receiver. You then should have a cable leaving the 3-4 port of the Dish receiver going to the IN PORT -usually the top- of the VCR. Directly below this port on the VCR you may have another cable which ould connect to the antenna port of the TV or you may have a set of red/white/yellow cables that need to be on the output port of the VCR of the corresponding color and connected to the INPUT PORT of the TV in the same manner. The DVD will be connected the same way with red/white/yellow but mat go directly to the TV on another set of IN PORTS or they may go to the IN PORTS of the VCR if so equipped. If your systems is different let me know what kind of connections and type theey have or give me the make and model number of the TV/VCR/ and DVD and I will look them up and tell specifically what to connect where. Thanks for using Fix Ya
Mar 19, 2009 | DISH Network 311 DTV Receiver
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
grateful,
kay
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Code for trutech
dish network remotes dont work with very many tv/vcr or tv/dvd combo units
Jul 11, 2008 | DISH Network IR Remote Control
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
