When i start the through error overclocking failed! please enter setup to re configure your system how to solve this problem
    President:
  • 2,571 Answers
If you dont know how to reset your bios settings back to default, maybe you should not be overclocking.
Enter your bios (check google for the key you need if you dont know it)
click default settings
Posted on Jul 27, 2010
My win xp has a coprocessor error can you kindly tell how to fix it my problem includes a bus controller error
Hi
Assuming you have not tried to overclock your processor, it would seem as if this is a BIOS or Motherboard Chipset Driver conflict or corruption.
Try first to clear the BIOS.
To enter BIOS (check bottom of POST screen for the correct key to enter SETUP), when in SETUP, select correct key for Reset to Default Values, then press F10, then press enter.
If resetting BIOS does not fix the problem, reinstall the Motherboard Chipset Drivers and then restart the computer.
If you did try to overclock the computer, then enter the BIOS and reset BIOS to default values, then save changes and restart computer.
Hope this helps.
Aug 22, 2011 | Computers & Internet
I have some problem on my PC which is running window XP pro. When I switch on my pc. It will prompt me the message below: ''Overclocking failed. Please enter setup to re-configure your system. Press F1...
The BIOS settings are wrong. Press F1 when the pc starts to enter in the BIOS then on there you will see the Load default settings option: select it, Save and Exit. If the problem isn't fixed then you have some jumpers on the motherboard that are switched wrongly - take them all out and try again.
Nov 12, 2010 | Computers & Internet
System failed due to cpu overclocking. Not setup for overclocking in the bios.
Reboot, and enter BIOS SETUP mode.
Choose "Load Default Settings".
This will "undo" any overclocking of your motherboard and of your CPU.
Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
When I turn on my computer the first thing I see is Sony Ericsson error in configuration. This does not appear on my 'phone and does not seem to affect anything but I just want to know what it means please...
This might be some failed software link. You can find these softwares link on start up at Start->All Programs->.Startup in startup remove any entry that looks like Sony Ericsson.
Also, if XP you can go to run and type "msconfig" and hit enter - on System Configuration Utility-. goto "Startup" tab and remove/uncheck any entry that matches error you receive frequently after booting up. This should solve the prob
May 13, 2010 | Computers & Internet
OverClocking Problem when startup my system
Most motherboards have settings that allow the board to try and overclock itself upon bootup. Take a look in your manual and it should lead you to the correct setting in the bios that will allow you to have the computer boot up in normal mode. Failing that, you may have to force the motherboard back to the default setup. There is a jumper you would have to move, then you would remove the battery from the motherboard. Check your manual for how to clear the CMOS settings if you need to do that step.
Jul 10, 2009 | Computers & Internet
Configuring canon ir400
diag board failed error in canon ir 400
Jun 10, 2009 | Canon imageRUNNER 400S Copier
Motherboard with mistake in the initialization
after changing the battery the problem is suppose to stop but since it continues i think u have to set the date and then save the changes made after saving cos is not all about changing batteries most times too the new batteries u just bought may be bad as well. so set the date and time then save changes i think it shoukld work well.
thank u
May 29, 2008 | ASUS P4V8X-X Motherboard
Oc failed enter setup to chwck oc settings
Could you please give us more details such as which computer (model number) and motherboard you're using? Do you know how to overclock and that's what you were doing? If so, you didn't overclock correctly and you need to change the settings back to the normal settings for your computer to boot up properly. You can change the settings in the BIOS, or "setup".
Jan 09, 2008 | Computers & Internet
OVERCLOCKING
Hi, On other motherboard models of Asus, similar problem was corrected by: 1. Updating the BIOS; 2. Actually overclocking the FSB to slightly higher than default (say 170 or 175 from 166, 140 to 150 from 133); 3. Slightly increasing the default processor voltage supply by increments of 0.05; 4. Replacing the 3.0 volts Lithium battery; 5. Replacing the memory to next higher speed; Never had problems like this with MSI, ECS or Intel boards. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | ASUS P4S800D-X Motherboard
Problem restrart pc /NO AUTORESTART
It sounds like you're trying to overclock your CPU, and you have exceeded what the CPU is capable of, under the current conditions. When you start the computer, enter BIOS setup (e.g. press the DEL key), and adjust the CPU settings to default. If you're not sure how to do this, choose the "LOAD OPTIMAL SETTINGS" or "LOAD DEFAULT SETTINGS" option from the main BIOS menu. If you are not getting this error until after Windows has started, then there is software installed that is trying to overclock the CPU for you. Uninstall it. It may be a program provided by Asus, or may be a third-party program. It will probably have "tweak" or "overclock" in the name. Overclocking can achieve an increase in performance, but will void the warranty, and does reduce the lifespan of the parts, and tends to make Windows crash more often. It can cause immediate failure of the parts. It should only be done if you understand and accept the risks, and have decided the reward is worthwhile. For most users, it is not worth it.
Oct 01, 2007 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
76 people viewed this question
Alun Cox
David Payne
David Payne
