Question about Kenmore Kitchen Ranges
Canada Model C970-502021 Manufactured March 2004. 2 large burners go to maximum heat at all settings of the control. At times burners turn on when control is in 'off' position.
  • 521 Answers
SOURCE: burner on range will not turn off
  1. all these problems are given in the link below and the solutions with diagram is given in it
  2. http://www.applianceaid.com/micro.html
  3. A common flow chart for microwave repairs
  4. A breakdown of a newer counter style microwave
  5. Door switch caution and repair help
  6. How can I get at the handle screws on my microwave to replace the handle? This has a common GE style microwave picture to help you.
  7. How to install a common over the range microwave
  8. Important Disclaimer
  9. I set something on fire in my microwave and now it is dead...help!
  10. My GE OTR ( Over The Range ) microwave is running but will not cook
  11. My Frigidaire microwave is flashing a fault code in the display...what's up?
  12. My GE microwave is flashing a fault code in the display...whats up?
  13. My Panasonic microwave is flashing a fault code in the display...what's up?
  14. My Sharp microwave is flashing a fault code in the display...what's up?
  15. My Whirlpool microwave is flashing a fault code in the display...what's up?
  16. My microwave light bulbs burnt out...caution!!
  17. Ohm testing an capacitor
  18. Some common Microwave FAQ
  19. Some common components and how to check them with a ohm meter - like magnetron, high voltage transformer, high voltage capacitor, door switches and high voltage diode.
  20. Stainless Steel Cleaning
  21. Sparks from inside the oven area....why?
Posted on Aug 27, 2008
ronaldsuboc
  • 449 Answers
SOURCE: I have a Kitchenaid Superba
hi!!!
try to check the tube may be clog
or there something block on the tube
or check the adjustment control!!
Posted on Sep 21, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
Recall on camry 2004 Le
Summary: Toyota is recalling certain model year 2004 avalon vehicles; 2004 and 2005Camry, Camry Solara, highlander, and sienna vehicles, 2006 highlander hybrid; 2004and 2005 Lexus ES330 and RX330; and 2006 Lexus rx400H vehicles manufactured from June 1, 2004 through March 31, 2005, equipped with the 1mz-fe or 3mz-fe ...7 days ago
2004 Toyota Camry Recalls ' CarComplaints.com
https://www.carcomplaints.com/Toyota/Camry/2004/recalls/..
Recall on camry 2004 Le Google Search
Oct 28, 2017 | Cars & Trucks
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Landmann 12376 ignition
Firstly, check the distance between ignite and burner, the spark must contact with the hole of burner.
secondly, turn on the control at maximum level then keep and push control knob try to Push-button Piezo ignition several times.
Finally, If you do not find out any trouble with gas supply, connection and assembly, do the same with step 2 however, Instead of push the button use the paper or wood with flame on to ignite for side burner for the first times, after that keep it running for few minute to heat burner, then turn off then use Push-button Piezo ignition to ignite.
With my experience it can work 100% after you heat the burner, if not call me. ^^
Aug 14, 2012 | Landmann 12376 Gas Grill
Model EW30ES6CGS2 galss cooktop Front burner has 3 settings: the samller one heats and the large one heats, the middle does not heat up. Would you mind telling me what you think the problem might be. Range...
the stove you have takes someone with an electrical knowledge to test and you don't want to break the to!!!.that said test burner for continuity if there control board bad
Dec 21, 2009 | Electrolux Cooktops
I turn my burner on at medium -no problem. When I
If you cannot regulate the temp on any surface element the problem is not in the element but rather the "infinite" switch. You need to replace the switch's if you can't control the hi and low on the burners. The switches will be different for the small burner and the large burner because of the different wattage on the burners.
Nov 11, 2009 | Kenmore Kitchen Ranges
My dual size burner only goes large no matter the
You will have to have the potentiometer switch replaced that controls the burner.
Aug 30, 2009 | Jenn-Air Cooktops
Model # 04570-035 Elisa Crib March 22/2004.. can't find the hardware and one wheel caster? can I buy all that separetly?
Vancouver-based manufacturer Stork Craft is voluntarily recalling more than a million baby cribs in Canada and the United States over a potential suffocation hazard.
The cribs were manufactured in Canada, China and Indonesia between May 2000 and November 2008, the company said in a release.
About 494,000 of the cribs were sold in Canada and 535,000 in the U.S. in several retailers such as Wal-Mart, Kmart and J.C. Penny, as well as on several websites, including Amazon.com, Babiesrus.com, Costco.com and Walmart.com, the U.S.Consumer Product Safety Commission said in an advisory Tuesday.
You may be entitled to receive it for free. Please call them to verify.
Aug 14, 2009 | Storkcraft Baby Elisa Crib
Burner works on high (9), loses heat at medium (5)
The control is bad. I assume the burner worked on the other side?
eric
Jul 03, 2009 | Kitchen Ranges
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
Kitchen Ranges Logo
251 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
