Sagem DTR94 hd freesat. help required please.when
Sagem DTR94 hd freesat. help required please.when I try to change channels I get...you are already watchingecording two different channels. select an option. theres only one and it says cancel channel change. as far as I know im not watching or recording any channels.i got the box back to factory settings and set it all up again.but alas to no avail.its says exactly the same thing.can anyone help?many thanks.derek
Benimur
  • 6966 Answers
SOURCE: reset tv to factory setup
Most current TV units can be reset to default factory settings by being unplug from the mains fro at least a couple of hours (or overnight).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
Nova_1
  • 196 Answers
SOURCE: record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Posted on Oct 12, 2008
maatmartin7
  • 1229 Answers
SOURCE: CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Posted on Aug 12, 2009
keithkalish
  • 146 Answers
SOURCE: kids fooled around with the remote and got into
Here is what you need to do to get back to the original configuration: Setup > Factory Reset by Input, and confirm that you want to reset the settings.
If the reset you require is to correct a more serious issue, you may want to try an EEPROM reset. If you call Amergence Technology at 866-965-3842, their Level 2 Tech Support agents may be able to walk you through it.
I don't see where in your user manual that the kids can change the firmware, here is a link to an online copy of your user manual if you do not have one handy.
http://www.docstoc.com/docs/7202968/Olevia-LT26HVE-and-LT26HVX---User-Manual
Your best bet is to rest to factory settings that should clear everything up for you
Posted on Oct 01, 2009
Forgot parental code sagem dtr94
You will need to call the tech support center for the game console, if there is a way around the code they will be the only ones that can provide the information on how to do it.
Feb 06, 2012 | Video Game Consoles & Games
Need a master code to reset my dtr94 hd freesat tv reciever/recorder
From memory you need to get the channel list up then press green to unlock each channel in turn if any have been locked.
Aug 08, 2011 | Sagem PVR 6280 Freeview DTV Receiver /...
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
How do i activate my usb port on my sagem DTR94 HD Freesat
Can you please activate my usb port on my sagem DTR94 HD
May 12, 2010 | Televison & Video
I can't get Channel 4, E4, More4 etc. on freesat
Channel Four is available on Freesat as follows:
Channel 4 Freq 10729 Vertical 22000 5/6 -
Enter these figures on your 'Search for Channels' menu, and it should turn up Channel Four.
Mar 10, 2010 | Grundig GUFSAT02SD
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
No sound on hd tv thru freesat
HDMI to DVI adaptors do not always support audio.You have to run seperate audio into the TV.
Jan 12, 2009 | Televison & Video
My sagem DVR 6200T UK displays ER 07 on the box
I HAVE HAD SAME PROBLEM. I HAVE TWO OF THESE RECORDERS AND ONE IS OK. I SWAPPED THE POWER LEADS FROM THE GOOD ONE TO THE ONE THAT IS NOT WORKING AND IT WORKED SO ALL YOU NEED IS A NEW POWER LEAD FROM SAGEM IN FRANCE.COST £10 PLUS POSTAGE.
CHEERS
Dec 17, 2008 | Televison & Video
Record and watch different channels with freesat
Oct 12, 2008 | Televison & Video
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
